Boxed weld in subframes or Tube Bolt ins?
Old 03-01-2008, 05:09 PM
samson_420's Avatar
Default Boxed weld in subframes or Tube Bolt ins?
That is the question. I narrowed it down to the UMI bolt in subrames or the Boxed weld ins.
Even though I want the bolt ins, I will get them welded later on after I bolt them in.
Which are realy better? Or does it matter?
Old 03-01-2008, 05:23 PM
badazz99ta's Avatar
i think the boxed are a little stronger than the tubular, but with less ground clearance. i used to only want boxed. but after a lot of reading there are a lot of people with tubular. so i am going with the umi tubular sfcs and then im going to get them welded.
Old 03-01-2008, 09:34 PM
samson_420's Avatar
I don't know, the boxed just look tough.
Old 03-02-2008, 08:08 AM
LS1TECH Sponsor
Steve Burger's Avatar
We have tubular CM weld ins that are very strong.
I'm not a fan of bolt ins.
Old 03-02-2008, 09:27 AM
koolaid_kid's Avatar
It depends on your expectations. If you are going to road race, I would do boxed. Stronger structurally, but the clearance issue is a PITA.
If not, I would go tubular. And weld in, either way, just because.
Old 03-02-2008, 10:09 AM
UMI Performance's Avatar
Hello,
We have good luck with both the tubular style and boxed style, for strength reasons you would be fine with either choice.
A few things that might help you make a decision- The tubular ones are available with the bolt in option but can be welded at any time. The boxed are not and are weld in only. The tubular set-up tucks up a lot tighter to the vehicle and can not be seen from the side of the vehicle. The boxed hang down slightly and if a bright color such as red is chosen they may be visible if you do not have ground effects. But the boxed do not reduce ground clearance.
If I can help anymore please ask. Thank you!
Ryan
Old 03-02-2008, 02:23 PM
DSkyles's Avatar
I have kenny brown boxed weld-in and they tuck up real nice. I had a chassis shop put them in for me. No matter what weld them in.
Old 03-02-2008, 05:02 PM
djfury05's Avatar
get the tubular bolt ins, and get them welded, you won't notice a difference in the two. You are going to be just fine my friend
Old 03-02-2008, 05:30 PM
EastTnZ28's Avatar
I put in a set of 3 point bolt in UMI's last night and the fit and look is awesome. UMI has some of the best stuff out. Very nice product.
Old 03-02-2008, 06:43 PM
samson_420's Avatar
Are the UMI boxed subframes realy noticable if painted black? Eather way I am pretty sure I will go with the tube bolt ins then get them welded later.
Quick Reply: Boxed weld in subframes or Tube Bolt ins?
