6spd swap 4L60E to T56
Old 03-03-2008, 01:29 PM
TopekaFlames10's Avatar
Talking 6spd swap 4L60E to T56
Soo I need help guys! I blew my tranny a few days ago and well i am thinking that since i have to do something with it why not go all out and make it a 6spd. I know everything that you need I just am really not sure on how to do it. Does anyone have and write ups on how to do it? Or just any helpful information?
Old 03-03-2008, 01:50 PM
firechicken_98's Avatar
Here you go:
https://ls1tech.com/forums/manual-transmission/200480-m6-a4-a4-m6-conversion-info-requested.html
Just read through that. There is a write-up in there also.
Old 03-03-2008, 03:01 PM
camaroguy26's Avatar
yeah, the site firechicken posted is a sticky. It gave me all the info I needed and all those guys helped me a lot. some good pictures in there and a couple writeups.
Old 03-04-2008, 09:34 AM
jmm98LS1's Avatar
I also just recently did this swap using the info in the sticky. If you need any help, I'd be happy to......looks like we're from the same town.
Old 03-04-2008, 12:49 PM
Z28LS1camaroguy's Avatar
got mine transfered to a 6 speed after i blew up the A4 at the track, i figured why get a new auto when i can get a new six speed for cheaper and have what ive always wanted.
Old 03-04-2008, 09:17 PM
How hard was the swap?? Everyone is telling me not to do it....jmm98Ls1... i live in topeka where r u from??
Old 03-05-2008, 09:03 AM
bjamick's Avatar
The thing that people say is the hardest, is trying to figure out how to get the reverse lock-out to work right. But you have to run a wire to pin 44(??) I think to have it like the GM has theirs. Ill be doing this swap veryy soon myself and hope it goes pretty smoothly.
Old 03-05-2008, 10:19 AM
jmm98LS1's Avatar
I'm from Topeka too. The swap is absolutely not hard at all.....in fact I'd say a cam swap is more involved. The sticky at the top of this section has absolutely everything you need to know. I did mine in my freezing cold garage on jackstands with hand tools. Everyone told me not to do it too....don't listen to them, I'm sure glad I didn't.
Old 03-05-2008, 10:42 AM
The swap isn't hard. If you can drop a transmission, then you can do the swap. The wiring was very easy. The hardest part was finding all the swap parts that you need.
As for the reverse lock-out, I just left the solenoid in there and didn't wire it up. You have to jam it over to get it in reverse. I just left it there b/c I wanted to be sure I didn't accidentally go in reverse on the hwy.
Old 03-05-2008, 12:39 PM
I have never seen your car around town it looks really good though!!! and so on the reverse lock out what happens if you just dont have it?? (i know this is a stupid question)
Old 03-05-2008, 03:36 PM
bjamick's Avatar
Its purpose is to lock you out of reverse until you hit the brake or clutch or something like that. So if you leave it out then you better watch out on 4-5 shift and your 6-5 downshift so you dont accidentally go into reverse and fubar your tranny .
Old 03-05-2008, 03:50 PM
jmm98LS1's Avatar
Thanks....it doesn't get out much, I've only put 700 miles on it in the last 15 months. Like bjamick said, all reverse lockout does is to prevent shifting into reverse when you meant to shift into 5th. The solenoid is active above ~3mph and closes the reverse gate. Below that mph, the solenoid retracts allowing you access to reverse. It's not required to keep it (I removed mine), you just need to be conscious of what you're doing when shifting into 5th gear. Even if you accidentally shoved it over into reverse, it wouldn't actually go into gear....just make a nasty noise at ya and buzz your hand.
Old 03-05-2008, 08:08 PM
FNQUIKWS6's Avatar
Had mine done almost for a year now. NO regrets at all. You can sometimes find a whole "kit" to do the swap. If you need some help let us know.
Old 03-05-2008, 09:04 PM
TODDS93T/A's Avatar
i just listed every thing you need to get you were you need to be for your swap let me know ill owrk with you thanks todd toddrgudde@yahoo.com
Old 03-06-2008, 08:09 PM
Does anyone have any ideas on where to find a good T56??
Old 03-06-2008, 08:15 PM
Black02SLPSS's Avatar
I dont think you really need a reverse lock out. You really have push pretty damned hard to the right in order to get it into reverse, not something you would accidently do. Oh and for the above question, i found mine in the classified section so thats where i would start
Old 03-06-2008, 08:21 PM
I have looked under the classified and there are none in there!!! any other ideas
Old 03-06-2008, 08:28 PM
How much are you lookin to spend?
Old 03-06-2008, 08:36 PM
I am willing to consider anything right now I just wanna find something!! My car needs to be running soon she looks sad sitting in driveway with blocks behind it!!
Old 03-07-2008, 11:09 PM
So with the computer can 1994 computers be reprogramed or do you have to get a whole new one?
