How long to install a cam, springs, double roller chain?
Re: How long to install a cam, springs, double roller chain?
Your first time will take approx. 10hrs. of work.
If you have 2 days you will be fine, work at a steady pace, don't rush.
Will 2 days be enough? We are using air tools.
clint, you can do it in one day no problem. The biggest problem will be getting the oil pan off. It's pretty straight forward and make sure you Loc Tite the cam bolts.
Good luck, if ya need any help lemme know.
Ummm why does he have to take off the oil pan for a cam, valvespring, and timing chain swap?
NOTE that only F-body guys have to do that. C5's dont require it.
all you have to do is unbolt and drop the pan down, youll get the pickup bolt off then the pump, vettes have to remove the rack and pain in the *** brake module,, oh ya dont drop a lifter
