wanting to know if gm part #12553160 HEAD GASKET WILL WORK ON A .40 OVER LT1
Old 03-04-2008, 09:15 PM
meangreeneyz28's Avatar
Default wanting to know if gm part #12553160 HEAD GASKET WILL WORK ON A .40 OVER LT1
Will The Impala .28 Head Gaskets Work On A .40 Over Lt1 Part #12553160?
Old 03-06-2008, 08:23 AM
FlamingChicken's Avatar
depends on the gasket bore. you want at least .040 larger (believe thats what cometic says) so the gasket bore should at least be 4.080. also depending on deck volume that might be pushing it being so thin
Old 03-07-2008, 02:07 PM
thanks F.C.
Quick Reply: wanting to know if gm part #12553160 HEAD GASKET WILL WORK ON A .40 OVER LT1
