How would this cam be on stock heads?
Im thinking about getting a cam and wanted something close to these specs:
212/220 .515/.550 114LSA
Would this be good for a cam only with stock heads and 1.6 RR's??
Its my DD and only has 45K original miles. I want to keep the power band in the low and mid range. Its an A4 with 3:23's. Eventually ill build a motor but i just want some more power for now. Why would u go with a 112lsa? I dont want a choppy idle really.
It would be fine on stock heads. I wouldnt get a cam with such a wide lobe separation personally. Check out the Crane 227 (210/224) known to really perform and sounds pretty stock with a slight lope.
https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
wow the crane 227 looks pretty good, close to what i was looking for... Id like a "torque monster" lol. why are the specs different on this link from a sponser then from the cam swap guide:
http://www.thunderracing.com/catalog...d=310&pcid=122
Out of curriosity what cam would be commended if you wanted to the upgrade the cam with stock heads and eventually switch to LE stage 1 heads?
Thanks for the insight
Brewski
Brewski
