What kind of power to expect? S88/408
Build details....
Iron 408ci
Diamond -28cc pistons
Callies compstar crank
Callies compstar rods
Custom grind cam from cam motion
FAST 90/90
AFR 225
OFI T6 kit w/ S88 turbo
4" DP
4" Exhaust w/ dynomax ultraflo muffler
Built T56
Textralia exoskel clutch
Dana S60 rear w/ 3.54 gears
Have all other supporting mods and suspension too. Looking for maybe 15psi on pump for the street and 20psi and good gas for some good track times. What kind of power should I be looking at?
Anyone else w/ a similar combo have any Dyno/track #'s.
Thanks for your input!
Iron 408ci
FAST 90/90
AFR 225
4" DP
Built T56
no title here
That is the same kind of setup I am going to run. I am going to run a 408 with a 236/236 cam and Dart 225 heads. I should get a LS6 intake manifold but I am not sure about the FAST 90/90 setup. I might do that. My goal is 15-18psi street and 22-25psi on race gas. I will be using meth and a A2W IC. My goals are about 800-850 to 1000+ plus, I am a M6 car as well
The car is gonna be freakin fast thats all you need to know
lol
I say somewhere 850-900rwhp with pump 15psi
track times can be anywhere low 11s and low 9s depends on the weather, weight of the car, 60ft and how good can you drive
lol
ANy pics of the car or the build??
Keep us posted man.
lol
lol
Keep us posted man.
Thanks for the responses guys.
Some pics....
Custom grind cam from Cam motion.
TSP 408ci, 8.7:1 compression, Callies compstar crank, Callies compstar rods, Diamond -28cc pistons, 6.0 Iron block, ARP everything
BMR tubular "Turbo" K-member
Valley cover thats been modified/powder coated
Painted my FAST intake black/red
AFR 225's, 72cc, .660 lift springs
BMR Tubular lower A-Arms
ARP head studs
Cometic MLS head gaskets
Rollmaster dual timing chain set
Comp "R" Hydraulic roller lifters
BMR tubular upper A-Arms
4" Dynomax ultraflo, 4" turndown
Some pics....
ARP head studs
im running a similar set up except its a 402 stroker ls2. im running the same heads. getting the long block from va speed inc. they told me that i should get about 900rwhp on pump gas on 16-18 psi. and 1200rwhp on 20lbs. you must configure the efficiency of your turbo too. usually if your running 20 lbs on that much of a stroker you gonna need a race gas tune or run a meth kit like i am
Nice choice on the rear end how do you like it??? I love my Strange engineering danas60. allot of people opinions on this rear is that its the best rear-end there is out for are cars its lighter than the 9in and stronger def a great discison. Here are the stats on mine…. 35spline gun drilled axles Detroit truetrac posi 4.10s/ bmr relo kit for the lcas/pst steel driveshaft/im putting 535rwhp threw a 3800 vig and its putting down low 1.4 60s on a 17in/r35/315 nitto drag radial its runing 6.7s at 102 in the 1/8th......Its a kick *** rear end great choice.
Looks like alot of us doing very similar setups. I'm running the same AFR heads as well but found the springs were not the best to get proper seat pressure for a turbo set up. I went with the crane 99893 springs now and also Ferrea super alloy exhaust valves to handle the heat. Anyway, nice setup buddy.
Dan
Dan
LS6Nz06 Is a bad seller!! Do not buy from him!! He sent me lowering springs and i recieved only 3 because one fell out during shipping. He is now ignoring my pms i havent heard anything from him in two weeks. Here is the link to the negative trader feedback https://ls1tech.com/forums/negative-trader-feedback/899589-ls6nz06-bad-seller.html
LS6Nz06 Is a bad seller!! Do not buy from him!! He sent me lowering springs and i recieved only 3 because one fell out during shipping. He is now ignoring my pms i havent heard anything from him in two weeks. Here is the link to the negative trader feedback https://ls1tech.com/forums/showthread.php?t=899589
To the op of this thread, your car is going to be sick.I would like to see what it does when complete.I will hopefully be doing the same setup this coming winter.I would like to see how the TSP short block works out.
I paid him over paypal and he took care of the shipping, so i couldnt have gotten insurance if i wanted it. Alls i need is this guy to respond and i am being ignored. I talked to UPS and now they are telling me that he has to deal with it and he isnt!
So because a shipping company lost a spring in transit to your house he is at fault? Did you pay for shipping and since you most likely did, did you opt for the insurance? If you didn't this is more your fault then his.Also this is not the place for you to talk about this, don't ruin a perfectly good thread.
