Turbo problem
Turbo problem
ok i am the 17 year old who did my own rear mount that i posted about i just did my turbo setup and but i didnt have time to set up my waste gate and then the lines to the bov and wastegate i guess the refrence lines but all the oil lines and everything is hooked up and the turbo is getting oil .....becasue it is still spinning what will this do to my setup if anyting .we relocated the maf sensor to the back by the cone witht the rear mount turbo........ok well ive been driving around and stuff and getting on it a lil bit but my car is freaking slow i am getting beat by cars that i kill before...shouldnt my car be running like it was
your MAF is in the back? put it back near the TB.... you need to reference your wastegate to the brake booster or you can overboost the motor and blow it up. the BOV should be referenced from the same spot as the w/g. is your pcm tuned at all for boost? you even shouldnt be driving it at all if it isnt tuned properly.
