tranny problems
tranny problems
its hard to to put the tranny in 1st or 2nd gear when going slow and getting it into reverse is hell (it takes two hands which sucks) it goes in fine when im driving but reverse doesn't. im bruising my hand driving in traffic does any one have any ideas? oh and the guy i bought the car from had t56rebuilds/sixspeedsinc rebuild it and it has a textrailia clutch in it with an adjustable master cylinder. i dont think i could keep driving it if it is like this please help
Thats probably the slave cylinder throw out bearing running on the fingers of the pressure plate . I am not an expert on the GM hydraulics but have messed with a few of them in the past . In my experience , the adjustable master cylinders have to be pretty much right on the money . If they are not you will either get too much throw causing the clutch to slip or not enough causing the clutch to not work .
As the clutch disc wears , the master needs adjustment .
