350 vs. 383 LT1?
Old 03-14-2008, 05:39 PM
hawk584's Avatar
Default 350 vs. 383 LT1?
as open as the topic may be, depending on set up, what size would / will create the more power from a rear mount?
Old 03-14-2008, 07:11 PM
CALL911's Avatar
383 over 350 for potential power. You won't really see that much extra HP, but you'll notice a bit more torque than you would with the 350. Should compliment a turbo nicely either way as long as the motor is built.
FWIW, and I know this is going to be off topic from the get-go, but I would advise against the rear-mounts. The front mount Turbo's are much more effeciant and power making capable, and guys usually have a TON less issues with them compared to the rear mounts.
