best aftermarket oil pan to buy?
Im putting together a 355 just wanted too know which aftermarket pan was good. I was thinking of buying a Canton myself also need too know about the oil pump and all the other parts underneath?
the only time you see it is when the engine is out of the car! or when your changing your 710. kinda silly to me, but if i knew the REAL purpose in the fancy smancy oil pans it might make a little bit of sense to me.
at the strip really. Adding oil capacity was on the top list list of mistakes drag
racers make.
Well I'm running a higher volume oil pump on my motor and at high rpms it will run the oil out of the pan and cause spun bearings. Plus I plan on road racing my car so the extra capicity will help when making higher g corners at higher rpms.
Plus you get to look cool buying 7 quarts at autozone instead of 5 like everyone else
