rear suspension ?
rear suspension ?
so im putting on 315s in the back i have the sportline springs and wondering how to get about a 1/2 inch lift in the back to clear the tire or do you think i could get away with fender rolling and pounding in the inner wells here is a pic for reff The tires and rims in the pic are the old ones i have TTII on the way 17*11 in the rear with some nittos 315
yep, they will definitely rub as it sits now. well first try rolling the inner fender well lip. it may be all you need to do. i wouldnt beat on it though, just cause that is good way to crack your paint.
if you still have your stock springs, you could cut a coil off of them and put them back in your car
