How Fast With How Small?
Old 03-20-2008, 05:41 AM
Silverback's Avatar
Default How Fast With How Small?
Those of you with a turbo setup, how fast have you gone or how much horsepower have you made with how small a down pipe? I want to hear from those of you that are running singles with 3 or 3.5” down pipes (<4”), and maybe some dual setups with <2.5” down pipes? A brief description of the setup would help keep the answers in context.
To give you some idea of why I’m asking, I originally set out to find a body/shell to build a turbo project in that I pretty much had all the running gear for, wanting to build a “race car” that could see some street time. What I ended up finding/getting a good deal on was a TA that was lot more complete than I hoped for, it even has working air conditioning and cruise control, it’s actually a really nice driver. So I’m thinking more like “Ok, street car that is going to see a lot of race time…” Looking at it, I think I can see how to wedge everything in it but I’m just not sure about the down pipe. 3” looks tight, and it looks like it would take a minor miracle to fit a 3.5”
Old 03-21-2008, 10:36 AM
Silverback's Avatar
So no one has run fast/made a good deal of power with a turbo setup using a 3" or 3.5" down pipe?
Old 03-21-2008, 04:37 PM
RW99's Avatar
I have the PT* kit with a T67; I'm pretty sure this is a 3" downpipe. It's a very tight fit. Numbers in sig.
Old 03-21-2008, 09:31 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
You can go really fast on a small downpipe. Jose at forced inductions went low 10s or so I think with a 3 inch downpipe in the 1997 SS on their site. I'll be running a 4 incher once I get mine finished. I'm guessing this is a third gen car?
Old 03-21-2008, 11:27 PM
engineermike's Avatar
9.9 at 146 mph on a single 3" downpipe at 17 psi. I'm pretty sure there's more in it too.
Mike
Old 03-23-2008, 11:58 PM
Silverback's Avatar
Well, the current car in question is an 87 TA, why, what made you guess that?
Engineermike, I’m pretty sure that your combination was one of the ones that I was thinking about, but I might be mixing it up with someone else, I thought that you measured some excessive hot side pressures, E/I pressure ratio and were going to go with something bigger. What hot side are you running on that 76 and what headers/manifolds are you using?
Old 03-24-2008, 05:56 AM
Originally Posted by Silverback
... I thought that you measured some excessive hot side pressures, E/I pressure ratio and were going to go with something bigger. What hot side are you running on that 76 and what headers/manifolds are you using?
I'm running a 3" log-style manifold feeding a .96 AR T76GTS. 3" downpipe to a 3.5" exhaust system with a Magnaflow muffler. At 17 psi boost the exhaust pressure is 34 psi. I had numbers as high as 48 psi at the same boost with an Aerochamber muffler and smaller intercooler (yes, it matters). I think it would benefit from a 3.5" downpipe, but it would be a real challenge to fit it.
Mike
Old 04-02-2008, 01:19 PM
Silverback's Avatar
hum... what size intercooler did you have and what did you go to (suddenly becomming a pertinent question since I'm rethinking all that to work with AC)?
Old 04-02-2008, 01:25 PM
I was running a vortech aftercooler that had over 2 psi drop across it. Now, I'm running a custom Bell unit that's 2.5 times the size of the Vortech unit and the pressure drop is <1 psi.
Mike
Quick Reply: How Fast With How Small?
