PCV Question
PCV Question
I recently installed taller proform valve covers and installed a valve cover breather on the driver's side cover. I still have the pcv system. Will this cause a problem and should I have some type of filter for the passenger side valve cover so oil doesn't get sucked into the throttle body since I removed the valve cover baffles.
Thanks for the fast reply and I've heard that having a breather causes a vacum leak. What did you put on your passenger side valve cover or did you just put the vaccum line back.
