Quicktime bellhousing question...
Old 03-21-2008, 10:37 AM
Luna's Avatar
Default Quicktime bellhousing question...
Got my quicktime bellhousing. Went to put it in and realized I have no idea where the bolts go...
There are 7 of the one on the left and 8 of the one on the right with nuts.
Where do these go? Does it matter?
Old 03-22-2008, 08:36 AM
Luna's Avatar
Nobody eh ?
Old 03-22-2008, 10:01 AM
John02SS's Avatar
The black bolts are for bolting it to the engine, although 1 short. I addressed this with them and they are adding a bolt to the packs now. The grade 8's are to bolt the motor plate to the bell housing on the bottom of the motor for it to met the 6.1 sfi rating.
Old 03-22-2008, 10:25 PM
Luna's Avatar
Thanks.
Thats kind of what I suspected but when there was only 7 of the grade 8 bolts I was pretty confused.
Old 03-23-2008, 06:15 AM
stevieturbo's Avatar
Totally different bolt set to what I got....seems very hit and miss !!!!
I got 7 M10x1.5 Allen key cap screws to bolt it to the engine.
Then about 8 3/8" nuts and bolts for the aluminium plate, to bolt it to the BH I assume.
Also...check the height of it. My BH was 1mm taller than the stock BH. Add the Alu plate, and that becomes about 4mm. Thats way over 1/8" for you guys.
That will place the trans further back ( or engine forward ) and also mean the slave is that distance further away from the clutch.
I used mine without the plate, and just trimmed it to cover the open part of my BH
Also, check the mounting holes to the T56. Mine were threaded 3/8" instead of the correct M10x1.5
needless to say, I am less than impressed.
Old 03-23-2008, 10:57 AM
Luna's Avatar
Do you now the height of the stock bellhousing? I sold mine before I got the quicktime one.
I really hope this doesn't become a problem.
Old 03-23-2008, 11:00 AM
https://ls1tech.com/forums/manual-transmission/857299-quicktime-bellhousing.html
Old 03-23-2008, 11:14 AM
Luna's Avatar
Thanks for the link. I'll have to measure mine and test fit it on the trans first too.
The gaps in my bellhousing for the slave hyd. lines are much much bigger. I will get some pictures and post up. Seems like this is still a product in development
Old 03-23-2008, 12:17 PM
John02SS's Avatar
Stevie, they changed it it looks like. The bellhousing is shorter than the stocker without the plate. The plate is .120 thick and is steel now. With the plate installed it is .060 taller than the stocker, which is acceptable to me as some of the twin disk stuff is a lil tight anyway. They redid the bell where the master/slave ports are, and it is correct now as is the bolt holes in the bell for the tranny to mount to. Seems to be a VERY nice unit after these changes.
Old 03-23-2008, 12:41 PM
Pretty damn basic changes IMO. So how the hell did they get them wrong in the first place ?
And a "thanks, we'll update that in future versions, we appreciate your feedback" isnt exactly the sort of support/response I wanted from them.
What about the customers who were supplied a flawed product, like myself ? I dont see any money coming my way for R&D
Old 03-23-2008, 05:36 PM
ss1
ss1's Avatar
John02ss, where did you purchase the newer updated version from?
Old 03-23-2008, 06:39 PM
John02SS's Avatar
I tried a sponsor on here and he never got back to me. I found this one on ebay for 417 shipped. It was dropped shipped striaght from Quick Time.
Old 03-23-2008, 09:17 PM
greysteel_M6's Avatar
M10x1.5x40's all around will work for both sets, the stockers are black 8.8's but I put 10.9'ers back in
Old 04-04-2008, 12:38 AM
Luna's Avatar
I just noticed another major problem with this thing.
Stock bellhousing on the right, McLeod on the left.
Now heres my quicktime bellhousing.
The starter opening??? Its totally open on both sides of the bellhousing ? Maybe I'm just stupid here but isn't this a problem?!
Old 04-04-2008, 11:01 AM
I doubt 40mm long bolts will work.
I measured my block as having 27mm of thread/pocket depth. QT flange is 8mm thick.
So if you try and screw in a 40mm long bolt, that bolt is too long by 5mm.
Old 04-04-2008, 05:34 PM
Luna's Avatar
what about the start hole??
Old 04-04-2008, 05:43 PM
What about it ??
Does it matter that its open in that area ? Its only a small opening.
Old 04-04-2008, 05:53 PM
Luna's Avatar
I guess it just seemed like it could be a problem. Get some water in there or something? I don't know.
Is it a problem or not really ?
Old 04-05-2008, 10:13 PM
Luna's Avatar
I must be the only one that really thinks this is a problem...
Old 04-06-2008, 03:03 AM
But why ?
Quick Reply: Quicktime bellhousing question...
