yank ss 3600 and traction
i have a 2002 a4 trans am and i have o.e.m corvette rims 19'' rear 18'' front on ttoyo tires. wondering if getting the ss 3600 stall will i have a problem on traction, also getting 3.73 installed, true dual exaust,tr224 cam thanx
Yes, traction from lower speeds will be non-existent unless you run a good tire. Nittos work well on the street, and MT ET Streets work awesome at the track. I run regular street tires on a day-to-day basis and my car will break loose at 50 on a cold day. Might be that PT4400 causing that, but you get the point!
my rear tires are pritty wide they are the same as stock c6 corvette wich comes like 400hp i believe, so my tires wouldn't handle a 3600 stall at 1st gear, does anyone know any stall or str i could get that i could keep my tires, they cost me $1000 and i don't want to have to change them
Uh with a stall your probably not ever going to get traction in 1st on street tires.... If you want to race get a good tire your not going to be burning the tires off everywhere just drive normal.
this guy is right, and sometimes depending on the dr..and how cold it is out side...ive got mine preaty much hooking on a warm day from a dig. but with a 315 bfg and a lil susp. mods... just got to play with it
You can always get two extra wheels and mount drag radials on them for when you really want to go fast.
im not gonna take off the rims or tires, if i stay with 3.23 and go with a 3000 stall will it make it easier to get traction. I understand what you guys are saying about not mashing on it but by doing that is there even a point of getting a stall in my case? thanx for all opinions
i guess i may not get a stall now, so with just full exaust and lid with stock stall and 3.23 is a tr224 cam ok or pointless? or would it be more wise to get a smaller or cheater type cam
