What happened!!!!!
What happened!!!!!
Me and my father got our cars retuned yesterday,and the resultswere good in one way and disappointed in other way, my dad changed his set-up from TEA 1.5 heads and XE-R 224/224/.583/.583 and all the bolt-ons and SLP exhaust he put down 407rwhp,then he changed his set-up to trick flow 215cc heads and the 228/230 cam that came with the package deal, and he didn't inprove at all it was a 407rwhp and his car is m6 stock rear -end with 4.10's,and on the othere hand i got his heads and cam(look in sig of mods) the only differance between the to is mine is a a4,with slp coldair induction and bbk80mm tband my car put down 400rwhp,what went wrong with my dads set up or is there anything holding it back .
1 Post
Seems like the added duration, added lift, and better flowing heads would have lead to some solid gains. At least 15-20 maybe more. Not sure what up bro, but good luck figuring it out. Post up when if and when you find something.
yeah the car was retuned yesterday 3/22/08 and has the LS6 intake,and both cars have stock injecters,dont have the dyno graph till tuesday cause there printer was broke,but will be sent a copy by email,and soon as i recieve it it will be posted,and the old dyne sheet of his past tune was lost, and it was done by TEA when they was in Bowling green ,ky, right before they moved to Ohio,both heads have 64cc chambers,the mods on my dads car is full bolt-ons (asp underdrive,kooks headers and y-pipe,slp exhaust,slp lid ,smooth belows,trick flow 215cc heads ,228/230 cam ,7.5 pushrods,harland sharp rockers,slp mas air,fan swith ,160 temp,the car is a SS(ss hood fully functional)4.10 gears(stock rear end),heavy duty clucth(don,t know what brand )
I am with this guy!! The restriction could be the stock injectors. I made 423rwhp through a slipping A4 with a PTC 3600 stall converter and stock 3.23 gears. Tell him to throw a set of SVO 30lb injectors in there and see what it'll make..
