Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
383 motor im thinking about selling but I have some questions first.
Old 03-25-2008, 11:42 AM
SpdFrk1990's Avatar
Default 383 motor im thinking about selling but I have some questions first.
I had a 383 built awhile back that was balanced with a 400 balancer and the fly wheel from my 90 camaro. If someone wanted to buy it for an auto would they be able to put a flex plate on it and a fluid dampener and not have issues or have to get it rebalanced I guess?
Thanks John
Old 03-26-2008, 02:09 AM
1997bird's Avatar
They would need to purchase a external balance dampner and a external balance flexplate (one or two piece rear main seal depending on the block used). It would be best if you could have the old flywheel spun up and checked to make sure the new flexplate matches it.
Old 03-26-2008, 02:36 AM
SpdFrk1990's Avatar
Ok I have the 400 balancer so basically they could just buy a flex plate and have it spun up to match the flywheel? Wouldnt the flywheel being heavier throw that off tho.
Old 03-26-2008, 03:43 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, if you think about it, a flex plate plus a heavy *** converter are not to far apart, it is the weight on the two that ballances it out.
Old 03-26-2008, 09:02 PM
kenSS's Avatar
i balance cranks everyday. was the motor externally balanced before. if it had forged internals more than likely it is inernally balanced. if thats the case, and internal balancer and flywheel/flexplate will work. if it is externally balanced, you will need to balance the crank again with the balancer and flexplate. unless you can wiegh the new flexplate and balancer to within a few grams of the original ones. if thats the case, you should be fine. but a new balancer and flexplate will have to be balanced with the crank. unfortantely, that's why externally balanced engines are not the way to go for high performance application. any more questions let me know.
Old 03-26-2008, 10:53 PM
1997bird's Avatar
The OP said that it was origionally balanced with a 400 balancer and a one piece rear main seal flywheel (1990), which is a external balance flywheel. Since he is going to use a Fluidampner, which you can't modify for balance, he doesn't need to worry about it. He needs to check the flexplate for balance in relation to what the old flywheel balance point was. This should get things close to the old balance job, but not exact. For a performance engine, internal balancing is worth its weight in gold for just about everything related to the internal engine!!!!!!!
Old 03-26-2008, 11:08 PM
SpdFrk1990's Avatar
This motor was out of a truck I had it balanced with my 90 flywheel. It is a 1 piece real seal roller block. The crank is cast but the rods are h-beam forged. The balancer is very much like this 1 http://store.summitracing.com/partde...5&autoview=sku
if not the exact one ide have to check though. It had a weight bolted on it and you could bolt different size weights on it if you wanted which I think they did when balancing.
Old 03-26-2008, 11:18 PM
1997bird's Avatar
From this last info, I would also spin the balancer up as well to be able to match the old one.
Quick Reply: 383 motor im thinking about selling but I have some questions first.
