the plug-ins on a T56
there are two electrical harnesses on the T56 tranny that are exactly the same size and fitment. first question is, what are they too, and second question is, since either one can go into each sensor, what would happen if the two were crossed?
The plugs can be reversed. I think they are color-coded. Black plug / black solenoid connector. White plug/ white solenoid connector. If they are reversed, you would have reverse shift complaints( high loads getting into the gate). You would also have no skip function but who would complain about that?
UNDER PRESSURE MOD
Easy way, but somewhat dangerous, to figure out the two is to roll down the street doing 5-10 mph and see if you can push to shifter all the way to the right with your foot on the brake, slowing down. Once you hit 1-2mph (I think that's the speed) you should be able to put it all the way to the right and get it into reverse.
Wow ! That would be very ill-advised. Why would you even suggest that? The REAL easy way:If you want to determine if the plugs are correct. Try shifting into reverse with the key on and then the key off. The key off will give you a resistance load ( but you can still get reverse) if correctly powered. If there is no difference key on/ key off, the plug is incorrect OR you have a fuse blown.
UNDER PRESSURE MOD
Calhoon, I'm not telling him to put it into reverse. And FYI, the reverse cylenoid will only activate when you are going forward at 2-3mph I beleive. So if he rolls down the road at 4-5 mph and can push the shift (with the clutch in) all the way to the right, then it's not hooked up properly. By no means should you actually put it in reverse, or let out the clutch.
I think your next try should be reversing the plugs.
Swapped plugs
This actually just happened to me on a LS7 clutch conversion for LS1.. What happened to me is that when the car was turned on it would lock me out of all gears but 1 and 4. The car didn’t have to be running for it to happen so I know it wasn’t hydraulics or shim clearances. To fix the problem I Swapped around the VSS and RL and BOOM! My headache was over 😀 I finally had full control of the shifter..
