vent tube on M6 Transmission
Can anyone tell me if I can make up the vent tube for the tranny with a hose and a valve?
if so, What kind of valve do I need. I need to do this since my tranny does not have one.
Also I need to know the part number for the belt using underdrive pulley (ASP)
thanks
thanks
As for the vent tube. A rubber hose and clams will work fine. I don't know what you mean about a valve. There should not be a valve that blocks air flow- the reason for a vent. A simple"jiggle cap" fitting like what is used on diffs will work.
