How to tell what series carrier you have.
Old 03-30-2008, 07:12 PM
onebadazzls1ta's Avatar
Default How to tell what series carrier you have.
I've found out that there are different series carriers for our cars I'm an a4 and I wanna go with 3:73's I have a diablo already. So is there a way to tell from our RPO codes in the glove box? Oh btw it's a 99
Thanks
Matt
Old 03-30-2008, 09:07 PM
common guys sheesh.
Old 03-30-2008, 09:11 PM
nomoneyz's Avatar
GU2 = 2 series carrier / 2.73's
GU5 = 3 series carrier / 3.23's
Those are the only ones you have to worry bout since your an auto.
Old 03-30-2008, 09:37 PM
thanks thats all i needed to know
Old 03-30-2008, 09:38 PM
oh btw which one am I more likely to have?
Old 03-30-2008, 09:47 PM
02T/A-WS6's Avatar
you could check your door code or if you know a common gear/speed/rpm you drive at you could verify it here
http://www.f-body.org/gears/
Old 03-31-2008, 06:48 AM
It's a gu2 it seems they make more stuff for the gu3 thought LOL go figure.
Old 03-31-2008, 10:23 AM
MattIROC's Avatar
You'll notice a huge difference going from 2.73's to 3.73's. I went with the 2 series Motive 3.73's (you'll need the 2 series in case you didnt know). I picked up 7 tenths with the swap and a 20 degree drop from seeing the track last.
Old 03-31-2008, 05:52 PM
wow that's awsome and yeah I figured I'll need the series 2 LOL.
Old 03-31-2008, 06:00 PM
how hard does it launch compared to stock gears? I mean it launches good now.
Old 03-31-2008, 10:58 PM
MattIROC's Avatar
It launches great. The rpms dont drop as much, meaning it stays more in the powerband. Even though I just have gears and a lid, it feels much different vs the 2.73's. I can roast them from a dead stop with ease. When I hit it from a stop and it goes to 2nd, it spins a little then hooks. Not too bad on a basically stock car. I only spent $355 for the ring and pinion, install, and fluids. Cheap mod for half a second!
Old 03-31-2008, 11:13 PM
SMALLBLOCKHERO's Avatar
you runnin a stock A4 or is it stalled? 7 tenths from a gear change?..thats awesome. i gotta put mine in soon.
Old 04-01-2008, 10:34 AM
MattIROC's Avatar
stock a4. I ran 14.14 @ 100 bone stock. 14.04 @ 101 with a lid (temp was the same), then the temp dropped from 80 to 60ish, and with the gears I ran a 13.31 @ 104.9 first pass. 60ft didnt change from before the gears (2.1's) I barely stalled the car on takeoff, but no spinning. I was hoping for 13.50's, but I thought it might do a little better. Definitely a good mod!
