Mcleod bellhousing any info?
Old 03-30-2008, 07:52 PM
2 fast 2000's Avatar
Default Mcleod bellhousing any info?
Okay guys I just had the bellhousing installed last week and ran my camaro for the first time. For some reason the damn thing pops out of second and third gear now. Its kinda like something is f*cked up in the tranny. The bellhousing moved the t-56 trans back so much that I had to shorten the driveshaft 1 inch. I've never had any problems out of the trans untill this install. Since everything has changed and moved so much could this be my problem? Anybody else had this problem. What could I do to correct this? Anybody else got this scatter sheild?
Old 03-30-2008, 10:22 PM
01350ss's Avatar
I have this shield. It's been in the car for about 3 years now. The only issue I have is that the rear plate on the bell housing is so damn thick that i can barely get a socket on my bleeder. I have never heard of a shaft needing modification from the shield install.
Call mcleod.
Old 03-31-2008, 08:23 PM
AzzBustin30th's Avatar
ive never had either of those problems, let only any problem with mine.
Old 03-31-2008, 08:48 PM
ls1 joe's Avatar
I have never heard of having to shorten the drive shaft. You need to call Mcleod because there is definantly something going on there.
Amber
Old 04-01-2008, 11:49 AM
LS1TECH Sponsor
badpewter-z's Avatar
put a few in and havent had any issues there a bitch to put it in but shouldnt affect the driveshaft at all. i think it only moves back 1/4" at most if i remember correctly
Old 04-03-2008, 10:04 PM
Well it moved my transmission back a 1/8th of a inch with that spacer plate that it comes with. I allready had a shorter driveshaft due to the dana 60. I mean my drive shaft yoke was all the way in the transmission. I was wondering since the tranny was moved back some, if it would mess up the geometry with the slave unit and all? I never had any issues with the tranny shifting untill the install of this bell housing and now it is very hard to speed shift into 2nd and third. The shop said they had to shim it after the install. Could this be where my problem is located? Did any of you guys have to shim the slave unit?
Old 04-03-2008, 10:05 PM
Oh by the way I called Mcleod and they wasn't to much help.
Old 04-04-2008, 10:20 PM
Did everybody on here use that little spacer plate?
Old 04-05-2008, 03:08 AM
jmd
jmd's Avatar
It would be worthwhile to check the gap between throwout bearing and pressure plate fingers. Then shim the slave accordingly. That's the location where distance will affect your shifting.
Old 04-05-2008, 06:30 AM
LS1Tech Sponsor
Slowhawk's Avatar
Sounds like your driveshaft was too long to start with.Then when you added the bellhousing it moved back 1/8" which bottomed the driveshaft into the tranny.You need to shorten the driveshaft before you wreck your tranny or destroy the thrust bearing in the motor.
