T-304 piping for custom turbo
we are currently working on a truck manifold system for the fbodies that we are going to market in both kit form and just pieces but we are still a month or two away.If you are still looking for something then just pm me and i will be able to help you
Been there doing that. New competition makes it more interesting .
The hardest thing I have run into with just doing hot parts is the DP. It's all real easy if you are sticking to one style of turbo that shares the same turbine housing. But when the turbo changes so does the DP.
I have found that offering just a Charge Pipe may work. Problem is if the end user can make his own DP then he has the skill to make his own Cross Over too.
Yeah, I could do that. Last time I tried this I was runnning the DP past the K-member. It turned into a what Turbo, What size V-Band, and What K-Member issue. I guess I could do it with a DP starter that a local exhaust shop could finish. Something that a customer could point down and run to the exhaust shop at least.
Hmmmm.....
Hmmmm.....
Hmmmm.....
Hmmmm.....
The rest is cake for em to get fabbed either by themselves or by a local exhaust shop.
J
