Best block for boost?
Old 04-02-2008, 09:58 PM
gearhead1186's Avatar
Default Best block for boost?
With price and strength in mind, which block would be the best to throw boost at. I've heard the ls7 cylinder walls are thin and wont hold boost as well as say the ls2.
Im looking for 700rwhp give or take so assume the psi needed to make that.
Old 04-02-2008, 10:09 PM
Darren P's Avatar
I think at 700RWHP you would be fine with either one
Old 04-02-2008, 10:13 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Well, just about any LS style block can hold 700rwhp without a problem. The iron blocks are probably stronger, but by the time you are making enough power to need something stronger than an aluminum block, the bigger concern is lifting the heads under boost. So then you will need either a warhawk or LSX block for the extra bolts for clamping force.
So having said all that, you can get iron 5.3L or 6.0L blocks for dirt CHEAP! You pay an 80# penalty over aluminum, but if that is not a concern for you, then look into an iron block. And try doing a little reSEARCH- there is tons of info in this section about block selection.
Old 04-02-2008, 10:38 PM
thanks guys...
i did a search and came across this.
https://ls1tech.com/forums/showthrea...ighlight=block
it seems like the general opinion is that aluminum will take 700-800hp and im looking for around 800hp. i guess ls7 is out since it has the thinest walls. im really looking to save weight and thats one of the reasons im looking at an ls block.
Old 04-02-2008, 10:53 PM
DownWithOPP123's Avatar
Dude look at Mike brown and steve turley. Pushing the ls2 block WAAYYYY past 800hp.
Old 04-02-2008, 11:08 PM
ChevyChad's Avatar
Tiago went past 900 rwhp IIRC with a 347 aluminum block.
Old 04-02-2008, 11:35 PM
52172's Avatar
700 rwhp will not stress any ls series block. even a rehoned 98ls1 block.
Old 04-02-2008, 11:50 PM
LS1curious's Avatar
Lest I read in sevral places those blocks are sleeved ?
Old 04-02-2008, 11:55 PM
52172's Avatar
the ls2 block is not resleeved unless it is stated so. the ls2 block will handle major power Mighty mouse is running one for quite a long time now without any issues. They will hold 1000 rwhp reliably. Once you hit that power level the clamping of the heads becomes the issue not the block.
Old 04-03-2008, 12:17 AM
thanks for the replies.. my goal is 800hp. no plans on going any further. now that we have the aluminum out of the way, is there any difference between the different ls that would benefit me?
Old 04-03-2008, 12:25 AM
52172's Avatar
doesn't matter if your talking 800 crank or whp you will be fine with either the ls1 or 2 blocks. The ls2 block is just slightly stonger than the ls1, but at you power level it does not matter.
Old 04-03-2008, 07:59 AM
Dumb Ass Vette Moderator
ls1290's Avatar
LS1Tech 20 Year Member
There are many people make 700ish rwhp with stock LS1 and LS2 blocks. Once you start to push 800 to 850 the block start to become a lot more important. Many people has push 850+ rwhp with dry or wet resleeved LS1 and LS2 blocks. The block makeup is not as important as the decking, bluesprinting, deburring, etc. The block really needs to be prepped correctly to make that kind of power.
Keith
Old 04-03-2008, 11:19 AM
thanks guys.. so it seems as though the ls1, ls2 is the way to go with a 700rwhp goal.
however ls1290 said "Once you start to push 800 to 850 the block start to become a lot more important." I dont want to be on the brink. I dont really want to resleeve the block.
Old 04-03-2008, 11:23 AM
FootLbs's Avatar
LSX block if you got thah money!
Old 04-03-2008, 01:36 PM
ls1290's Avatar
A stock block LS1 or LS2 block is fine for 700 rwhp. It would not hurt that have the block decked, line honed, and blueprinted The main reason to resleeve the block is to get larger diameter cylinder bores.
Keith
Old 04-03-2008, 03:45 PM
Keith
gotcha.. thanks..
its for a 69 camaro so at first I just want to drop in the motor as it is for budget reasons.. then as money collects again I will either turbo or s/c it.
plus the ls being aluminum was one of its selling points for me.
I dont think my needs warrant an iron lsx block..
Old 04-03-2008, 05:26 PM
sworaz's Avatar
Helpful thread.
Old 04-03-2008, 05:52 PM
2001WS6Vert's Avatar
I think you'll be fine with an LS7, I've had no issues with mine. Didn't that APS C6 Z06 make 1000whp?
Old 04-03-2008, 06:59 PM
InconFormula's Avatar
Yea we've pushed the ls2's way further than anyone else but these are not "stock" blocks, they have alot of work done to them to survive @ our power level.
I think a stock ls2 or probably an ls1 block would be fine for your build an iron block will work great also if you dont mind the extra lbs.
Old 04-03-2008, 07:24 PM
01ramair500hp's Avatar
i went with the 6.0 iron block. .030 over
Quick Reply: Best block for boost?
