changing LS1 intake to LS6.....
Old 04-03-2008, 07:53 AM
fastvet's Avatar
Default changing LS1 intake to LS6.....
Hey guys last night I was changing the LS1 intake to and LS6 and I completely forgot what you had to do to the aluminum piping underneath the intake. I know you have to cut it or weld it, or something cuz the LS6 intake wont fit on the engine without modifying the piping. What suggestions do you guys have for this? ......
Old 04-03-2008, 08:26 AM
Droptopws6's Avatar
This is what I used, you have to plug the rears.
GM part numbers
12602544 – Coolant Pipe
12602540 – Coolant Plug Qty 2
Heres a pic of the new front pipe installed.
Old 04-03-2008, 08:34 AM
SladeX's Avatar
Easier AND cheaper than buying/cutting/replacing coolant piping is to simply grind off the ribs on the bottom of the intake. On the coolant lines, simply remove the guide brackets, add some electrical tape as insulation where the knock sensor wires get pinched by the lines and you will find it will fit perfectly.
My2ndls1's Avatar
Buy the LS6 coolant lines or do some grinding on the bottom of the intake. This is what I did and it worked great! If you want to do this, do a search and you can find some pictures of where to grind. Good Luck!
Old 04-03-2008, 09:25 AM
2000KnightRider's Avatar
I bought my LS6 intake with the ribs already ground down on the bottom. I say grinding is the easier way to go...cheaper too.
Old 04-03-2008, 09:35 AM
bsf
bsf's Avatar
+1 for grinding.
Old 04-03-2008, 09:51 AM
andrew69_04's Avatar
the lines and plugs are like $35. im sure some of the sponsors have them. got mine off ebay
Old 04-03-2008, 10:02 AM
SS101's Avatar
thunderracing has them
Old 04-03-2008, 11:07 AM
bsf
bsf's Avatar
An additional point to consider is the effect of blocking the ports on cooling. I do not know if it has merit, but some have expressed concern that ditching the crossover can hurt cooling in one of the cylinders, #7 if IIRC.
Old 04-03-2008, 03:10 PM
fastvet's Avatar
what about the cutting, how does taht come in place. where do I cut??
Old 04-03-2008, 03:50 PM
SS101's Avatar
number 7 is notorious for melting down and taking out your motor with it. it has enough cooling problems as it is, i wouldnt try to aggrivate it.
Old 04-03-2008, 04:01 PM
Bad Blue WS6's Avatar
i've had mine blocked off forever,,it has had no issues, but to each their own
My SLP LS6 intake came with the coolant lines,,i paid 400 for it all brand new, shipping and all.
Old 04-03-2008, 04:19 PM
linegtdt52's Avatar
HEY DINGDONG, The 01 and 02 dont have that coolant piping on them. So how are you going to justify that THAT is the reason for the #7 meltdown. I think you should do some more research. It is preferred to have it set with the cross over pipes. If it scares you, put 2 cross over pipes in it and bend the back one to fit. Dont grind stuff!
Old 04-03-2008, 09:39 PM
SladeX's Avatar
I think someone should do some research of their own BEFORE ripping into others with names.
#7 is notorious for going when modded heavily. FI cars have a higher chance of experiencing this as does people that tune for more HP leaning out the mixture as much as possible.
This is why it's recommended that the injectors be flow tested sometimes with the fattest flowing one put on 7. Even the flow of the intake tends to promote air flow to 7 more than the others.
It tends to run hotter, many have killed rings on 7. 01-02 cars have a crossover pipe on the back, but when going to the LS6 intake some omit the crossover and simply plug it.
Grinding the ribs is cheap and doesn't require you to bleed air out of the coolant system. Just because you can spend $$$ for a complete SLP kit, doesn't mean it's the best or only solution.
Old 04-04-2008, 10:44 AM
fastvet's Avatar
So just cut the pipe, plug the back two holes, and keep the front ones running? Am I getting this right? So it should be ok just to run the fron two pipes and not the back ones right?
Old 04-04-2008, 01:20 PM
RoDan's Avatar
I think I would do the grinding but I have not been in that situation though so I don't know for sure. It just seems like the easiest, best route.
Old 04-04-2008, 01:29 PM
never said it was
Old 04-04-2008, 01:32 PM
RoDan's Avatar
yeah, I did some quick reading...i'd grind it.
Old 04-04-2008, 01:59 PM
Droptopws6's Avatar
Sladex You said:It tends to run hotter, many have killed rings on 7. 01-02 cars have a crossover pipe on the back, but when going to the LS6 intake some omit the crossover and simply plug it.
Can I get a picture or part number for this 01-02 rear cross over pipe?
Old 04-07-2008, 01:25 PM
Droptopws6's Avatar
Im being patient, still waiting.
Quick Reply: changing LS1 intake to LS6.....
