Settings for QA1 adjustable shocks
I have qa1 adjustables on all 4 corners. What would be the best adjustments for going to the track (at least a good starting point)? I can adjust for ride height and there is also a **** to adjust for softness or firmness etc. thanks.
LS1Tech Premium Sponsor
At the track leave the rears at 6 clicks from soft and put the fronts to 2-3 clicks from soft to help with weight transfer. It is going to take some experimentation with different settings to see what best suites you and your car.
wouldnt you want the fronts as soft as possible for drag racing? SO that the front end lifts up as much as possible and helps transfer as much weight to the rear? (unless you have so much power the car does a wheelie)
