D1 vs F1
Old 04-04-2008, 07:26 PM
rat496boy's Avatar
Default D1 vs F1
ive serched so don't yell....... but, how much bigger is a F1 then a D1? like around, and wide? also when mounted on a C5, how much higher does it sit then a D1? thanks.
Old 04-04-2008, 08:10 PM
z28boy's Avatar
They are the same size. Its what's inside that make them different.
Old 04-04-2008, 08:11 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=439
Check out the link above. Bob
Old 04-04-2008, 09:43 PM
Dumb Ass Vette Moderator
ls1290's Avatar
The F1 flows a 125 more CFM than the D1, but the biggest difference is the F1's step ratio of 5.4:1. This means that the boost will come in at lower RPMs than the D1.
Keith
Old 04-04-2008, 09:57 PM
BigBenz's Avatar
F1a For The Win!!!!!!
Old 04-04-2008, 10:04 PM
eb02z06's Avatar
F1A is a bad *** blower-but if your doing it go right to the f1c-runs cooler and no messing with adapters for the inlet.
Old 04-04-2008, 11:45 PM
rat496boy's Avatar
i get that much, i want to use a F1A or C on a project im working on, but a D1 is a tight fit as it is with a C5 kit. i wondered if i could upgraded it to the F1A without it getting bigger. if its the same physical size that would be amazing. so its true the D1 and F1 are the same size? is the F1A and F1C the same size?
Old 04-05-2008, 05:11 AM
EPP
EPP's Avatar
Thumbs up
The F and F-1A have the same diameter as the P-1SC and the D-1SC. The F and the F-1A are approx .38 longer, no real problem. The F and F-1A have the same inlet diameter.
The F-1C and F-1R are both larger than the F and F-1A blowers. That page I gave a link to above shows these differences. The F-1C and F-1R also have a slightly larger inlet diameter. It is 4.00" instead of 3.75". Bob
Old 04-05-2008, 12:40 PM
rat496boy's Avatar
does the F1 and the F1A make more heat? the reason i ask is its going to be basictly right in the radiator. im using a C5 LS1 kit in a 68 firebird. i know a D1 fits and works, but i want to step up. the car is driven alot, thats why im asking.
Old 04-06-2008, 12:38 AM
EPP
EPP's Avatar
We have seen higher inlet air temps with a D-1SC being pushed to it's max than an F-1A running at those same boost levels. Bob
Quick Reply: D1 vs F1
