Drive by wire to throttle cable
Will my 2004 PCU still work with my fast 92mm TB since it is not drive by wire? I read somewhere that drive by wire PCU's cant be used with a cable driven TB, is this true?
There is only 1 car in the US that uses the 1meg PCM with a throttle cable, the 2004 GTO. GM in thier infinite wisdom decided to save some pennys and not install the IAC valve driver into the 1 meg PCM's that were not put in GTO's. If you want to use that throttle body, the PCM will not be able to control the IAC valve
Sorry for the wait!
I looked up the service number on the computer they sent me and it actually is not from a 2004! So my comp will work but I appriciate the offer!
Nick
Nick
