32mm swaybar worth it?
Old 04-09-2008, 04:44 PM
LS1Aggie09's Avatar
Default 32mm swaybar worth it?
I am sitting on stock suspensions that has 114k miles on it. while i know its lots of miles, the car still handles ok. I might have an opportunity to get a swaybar for cheap and am wondering if its worth the effort to switch it out to help body roll.
My future plans are strano springs and pavlock panhard/LCAs in a couple months and koni's in a year or two.
Old 04-09-2008, 05:46 PM
Bow94z's Avatar
ya why not. I noticed a difference on my Z when i went from 30 to a 32 up front. Then i went ahead and did Strano springs and Koni's and left the 32/19 bars on...few weeks later i found a set of Strano 35/22 bars Oh man what a difference
How much is "cheap" for the 32mm bar? Is it a OEM bar or aftermarket?
Old 04-09-2008, 05:49 PM
LS1Aggie09's Avatar
OEM thats 8 years old...and cheap...well im hopin basically buying lunch or autocross entry fee (20 bucks)
Old 04-09-2008, 06:14 PM
Bow94z's Avatar
i'd do it, you will also need new Bushings to fit around the 32mm bar..But the end links are the same
I bought my OEM 32 from gyrhead.com couple years ago for 35$ shipped brand new
Old 04-09-2008, 06:39 PM
1Loudz28's Avatar
i put in a 1LE bar and poly bushings. noticed a difference over stock. worth it if you can get it for cheap. i think i paid about $60 for the whole setup.
Old 04-09-2008, 07:06 PM
BobDoLe's Avatar
upgrading that front swaybar makes a worthwhile difference in reducing body roll. just use new bushings (w/grease - i think i use lithium grease).
Old 04-09-2008, 07:12 PM
JD_AMG's Avatar
You have 114K miles on your stock shocks and are thinking about doing lowering springs before new shocks?
Save up and do shocks first...
Shocks>>>>>>>>>>>>>>>>swaybars>springs>other stuff
It would be a totally different story if GM put on some decent shocks on these cars from the start(like the 1LE cars), but they didn't...
Old 04-09-2008, 08:08 PM
equandt's Avatar
I did the GM 32mm front bar upgrade on my car with poly bushings. I also added poly bushings to the stock 19mm rear bar. This made a noticable change in how th car handled around corners.
This is a pretty good cheap suspension mod.
From what I read on this board the Strano sway bar package is the hot ticket right now, but the GM 1LE bars (32mm front, 21mm rear) is still a decent package for not much money.
Old 04-09-2008, 08:22 PM
coolformula's Avatar
Get the 35MM! Its great!
Old 04-09-2008, 08:27 PM
Shockwave179's Avatar
I did that exact same thing, it made a noticeable difference.
Old 04-09-2008, 11:14 PM
Breathtaker's Avatar
I'm gonna go for Strano 35/22 this month.
Old 04-10-2008, 12:38 AM
jmilz28's Avatar
The 32 front with poly all around was a noticeable reduction in body roll. The Strano setup was at least as big a jump again, only a tad lighter so (in my mind) it actually rides a touch better too. Can't go wrong. I know someone who has the 32 bar setup with poly...
