problem with smoke , need help
2000 ss with 15000 miles on engine, mods are afr 205s, comp cam ,kooks longtubes ory, ls6 intake, pcv conversion. the car smokes none stop now,gradually gitting worse, performed pcv conversion and still smoking. noticed when i removed the oil fill cap smoke pours out and some times blowes out the dipstick. i sure could use some advice???
White white smoke or bluish smoke?? If its oil smoke I can't help but think maybe if you had rings done, the rings didnt seat properly and that smoke is blowback
Did you check your rocker wipe when assembled?
A wide wipe off-center pattern coupled with high valve spring forces (especially the 8019's) will result in worn valve guides (which are bronze) and you have plenty of miles for that to have happened. To check, pull a couple of valve springs and try wigging the valves back and forth from the intake manifold towards the exhaust manifold.
