Texas Speed! Help!
I have the 4.25callies crank with 3.898 piston bore size with a 1.105 comp high. and the pistons are positve .200 estimated above tdc.i believe if i can get the 4.00 crank i can resolve my problem or can i get a shorter rod or a lower compression high?
Dont mean to confuse anyone im just wanderin what i should do to make the 4.250 crank work or just return the crank to recieve the 4.00 crank that i ordered.Even on the invoice i have purchased the 4.00 crank but i dont know what i should do.Im a novice ls1 builder so i have no clue of were to go from here any help is appreciated.
THANKS
In order to use that crank you will need to order custom pistons at about 1000 for the set. Yes you use different rods as well. There is only one builder that I know of on here that would even attemp to use that crank. Can it be used? Yes. My new combo has one in it. Is it for a novice builder..NO or shop.. NO!
If you want an engiine using that crank I'll guide you, pm me and I'll set you up with an engine utilizing it from a master builder. If you want to do it yourself don't contact me and consider yourself warned that you''ve got an extremely difficult build on your hands and will need to custom order parts for it.
S if i go with the 4.00 crank and the 6.125 rods with the 3.898 bore size at 1.105 compresion high my set up would be completly usable right? What cubic inch does that come out to?
