228/228 .588 lift 112 dyno numbers
Old 07-30-2003, 03:12 PM
TEX2KZ28's Avatar
Default 228/228 .588 lift 112 dyno numbers
I have a lid, ported mafs, loudmouth, hooker lt's and ORY and now a comp cams 228/228 .588 lift 112 lSA, 918 springs, and chromeoly pushrods and dyno tune. The numbers were 314 rwhp and 311rwtq before headers and cam and 362.1 rwhp and 353 rwtq after. It was dynoed at houston performance and I was told that their dyno is 10-15 hp lower than other dynos. Speed Demon motorsports did the cam and tune and it is a night and day difference. I am impressed with performance but not the dyno numbers.
Old 07-30-2003, 03:42 PM
dug
dug's Avatar
Default Re: 228/228 .588 lift 112 dyno numbers
THats a good gain but the numbers seem low like you say. Is that with the stock intake? The newer intake will give about 15hp with the cam.
Old 07-30-2003, 03:44 PM
TEX2KZ28's Avatar
yeah it still has the stock 2000 LS1 intake. I guess I will do that and a throotle body next. Will I need it tuned again?
Old 07-30-2003, 06:02 PM
Chubby's Avatar
48 HP and 42 TQ is a good gain, but ditto on the intake, LTs, TB waking it up a bit.
Greg
Old 07-30-2003, 07:28 PM
LSs1Power's Avatar
Greg
I agree with u, but i think he started with a low HP car. The car was making 314rwhp with all those mods which is very low. Most LS1's with LID, LM, are making between 325-335rwhp. Add another 48rwhp over that and u get 380's rwhp LS1. I think the cam did its job very well.
Old 07-30-2003, 07:34 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Add an LS6 intake, ported TB, and UD crank pulley and then you can really compare with some of the other dyno champions.
LS6 intake will add 10rwhp easily.
The intake and ported TB can lean you out a bit up top so tweaking the tune would not be a bad idea.
Old 07-30-2003, 07:40 PM
LSs1Power's Avatar
Hey Tex, i would put the stock MAF back and try to dyno the car again. This is the first time i have ever seen a bolt on LS1 makes less TQ than HP. Im talking before the cam and headers. So there might be something wrong.
Old 07-31-2003, 09:08 AM
CHRISPY's Avatar
yeah stock descreened MAF is the best. Use spray on contact cleaner to clean the wires as well before you dyno. That change with tuning, LS6 intake and ported throttle body will add another 20-25RWHP I bet.
Old 07-31-2003, 09:09 AM
TEX2KZ28's Avatar
Hey guys thanks for the tips. I will try to find a stock mafs. Track times will come soon.
Quick Reply: 228/228 .588 lift 112 dyno numbers
