started my turbo build!
Old 04-13-2008, 11:22 AM
scott94z's Avatar
Default started my turbo build!
Its been a wile "tooling up" , but i'm finally started
Here is some pics of the build so far
Attached Thumbnails started my turbo build!-pic170.jpg   started my turbo build!-pic171.jpg   started my turbo build!-pic172.jpg   started my turbo build!-pic176.jpg
Old 04-13-2008, 11:42 AM
Hugger Z's Avatar
Looks good. This will be interesting to watch progress. Nice collection of white Camaro's there!
Old 04-13-2008, 11:49 AM
scott94z's Avatar
Thanks!
I'll post more pics as things progress.
Its kind of funny, almost bought a 97 SS last fall, that would have made number 3 in the white camaro collection.
Old 04-14-2008, 10:51 PM
scott94z's Avatar
heres a few more pics
One more pic of the front end, and one compairing the tires
The smaller tires(mounted on the rims) are 27x10.5 et streets, these look tiny compaired to the monster 315/60/15 drag radials
Attached Thumbnails started my turbo build!-dsc00227.jpg   started my turbo build!-dsc00231.jpg
Old 04-15-2008, 01:38 PM
4SFEDZ's Avatar
looks sick
Old 04-15-2008, 06:19 PM
scott94z's Avatar
Originally Posted by 4SFEDZ
looks sick
Thanks!
Old 04-15-2008, 11:49 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I like your procharger sticker. How many cubes do you plan on using?
Old 04-16-2008, 08:40 PM
scott94z's Avatar
Yea, I used be big into Prochargers, I plan on around 400 cubes this time.
Old 04-16-2008, 09:51 PM
52172's Avatar
what kinda block and what bore and stroke?
Old 04-17-2008, 06:34 AM
Reject's Avatar
any more progress?
Old 04-17-2008, 09:12 AM
Fireball's Avatar
looks good. I don't think you should be running that big of an engine with the 47/88...turbine is awfully small and you'll probably see backpressure issues. I'd personally limit your motor size to 360cid
I came to the realization after alot of research that I'd be well over 2:1 pressure ratio with my 366 cid so I sold my gt4788 for something a bit more matched to the motor size
Old 04-17-2008, 08:10 PM
scott94z's Avatar
Yea, I'm thinking about going MUCH bigger on the turbo, When I bought the 47/88 I still had all of my LT1 stuff.
No progress... trying to decide on aluma stars or magnum wheels
The wife likes the all polished magnum 2.0's and I'm starting to lean that way too
Old 04-17-2008, 08:16 PM
scott94z's Avatar
LOL! I just realized on the title of this thread I typed "started by turbo build", opps should have been "started my turbo build"
Old 04-18-2008, 08:04 PM
4SFEDZ's Avatar
man just keep us updated
Old 04-20-2008, 10:43 PM
scott94z's Avatar
Started building the template for the frontend, as you can see there is still alot of work left, have to finish the side radius cuts, top and bottom radius. But you can get the idea, the pictures here do not do this justice, I'll have to take some better ones when finished.
Attached Thumbnails started my turbo build!-pic199.jpg   started my turbo build!-pic200.jpg   started my turbo build!-pic196.jpg   started my turbo build!-pic201.jpg
Old 04-21-2008, 04:55 PM
OWN3D BY MY PROF!
That's why I asked how many cubes you plan on using.
Old 04-21-2008, 09:58 PM
scott94z's Avatar
around 370 cubes, I will start off with this turbo and see where it gets me. And maybe I'll go bigger later
Old 05-04-2008, 10:25 PM
scott94z's Avatar
anyone seen 12"tall radiators?? I've got an idea to put the radiatior in the nose of the car. worried about cooling capacity also.
HELP!!
Old 05-31-2008, 08:13 PM
scott94z's Avatar
finally....more progress!
I need to cut a little more out behind the tire and cut off the fender lip to tuck the tire more,
going with full tub and stock style suspension
Attached Thumbnails started my turbo build!-dsc00342.jpg   started my turbo build!-dsc00343.jpg   started my turbo build!-dsc00344.jpg   started my turbo build!-dsc00345.jpg
Old 05-31-2008, 11:39 PM
Josh@KY-Turbo's Avatar
Looking good bro. Maybe one day I will start working on mine again.
