Will I want to get new springs?
Old 04-14-2008, 05:45 PM
verve_v's Avatar
Default Will I want to get new springs?
In two weeks I am going to be putting a rear mount turbo system on my 2k ws6. It has 70k on the clock and I was just wondering if it is necessary to put new springs on the heads. And if so, what springs? 918's or something? This turbo will only be running 5 to 6 psi tops for now. Also, at that boost with the high compression is it necessary to use an intercooler? FYI i have searched and found answers to all of my other questions so far.
Thanks in advance
Justin
Old 04-14-2008, 06:32 PM
GrandmasterCow's Avatar
An intercooler is always a good idea, and depending on how high CR might need meth also.
Old 04-14-2008, 06:34 PM
verve_v's Avatar
It is the stock 10.2 to 1. Well i think that is what stock is, but once again, this will only be 5 or 6 psi. Any idea on the springs?
Old 04-14-2008, 06:42 PM
deadmanTA's Avatar
Atleast 918's, that's what I have. The patriot duels would be the best.
Old 04-14-2008, 06:54 PM
mtg6486's Avatar
im putting in an sts turbo in my car and i just started upgrading the valve springs to 918 because i was told anything higher than 5psi of boost on stock springs will give you valve float
Old 04-14-2008, 07:11 PM
dcvingv6's Avatar
Definitely a good idea to do springs, 918's would be cool. When i got my springs, the patriot dual's were not that much more than the 918's, but that was on a sponsor sale, but its something to look into!
As far as the intercooler goes, you definitely would be safer to run one, or as stated you could run a meth/water kit, as both would lower your IAT's. Also this boost stuff is / can get addicting, so you will probably want to run more and thats when the IC / better springs might be more beneficial down the road.
Good luck on the install!
My $.02
Thanks...
--Mike
Old 04-14-2008, 07:21 PM
verve_v's Avatar
^ Thanks for the info dcvingv6. I think i am going to go with the 918's so i don't have to deal with twin springs and price. I am going to intercool now too.
"Also this boost stuff is / can get addicting, so you will probably want to run more and thats when the IC / better springs might be more beneficial down the road."
You are most definalty correct in assuming that.
Old 04-14-2008, 07:22 PM
verve_v's Avatar
Forgot to ask this question though. Do you have to have your heads machined for the dual springs?
Old 04-14-2008, 07:29 PM
dcvingv6's Avatar
No sir, i ended up putting them on the 317 6.0 heads (to drop my compression a little), but nothing had to be done to the heads. The only machining i had done was to port the heads.
Hope this helps!
Thanks...
--Mike
Old 04-14-2008, 08:33 PM
EPP
EPP's Avatar
The Patriot Gold spring kit comes complete with titanium retainers, and they're really not that much more than the 918's. Bob
Old 04-14-2008, 09:10 PM
Reject's Avatar
get duel springs, been reading alot of the 918's dropping valves and even with the redesign. i am going to swap back my dual springs on mine just for piece of mind, cheaper than buying new set of valves or pistion dont ya think?
Old 04-14-2008, 09:53 PM
verve_v's Avatar
^ Yeah, i guess the duals are worth a couple extra bucks. Dropping a cylinder would be a bummer.
Old 04-14-2008, 10:12 PM
kwiksilverz28's Avatar
The patriots are the way to go. Just installed another set Sunday on a buddy's car, and went on without an issue. Worked perfect!
Old 04-14-2008, 11:10 PM
verve_v's Avatar
How long does it take to put them on once you have the valve covers and factory springs off?
Old 04-14-2008, 11:14 PM
verve_v's Avatar
Another thing. Can someone give me a link to a sponsor site link with everything i will need for the dual spring install.
Old 04-15-2008, 04:31 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=651 Bob
Old 04-15-2008, 06:35 AM
Reject's Avatar
hmmm i would need to probably get some new oil seals as the ones from the 317 heads have their own base and i just noticed the patriots have a different style oil control seal. or you think it owuld work?
Old 04-15-2008, 08:35 AM
Websy21's Avatar
My vote also is to stay away from the 918's plus spending a bit more is usually worth it whether or not it is 'really needed'
Old 04-15-2008, 10:18 AM
verve_v's Avatar
Hey thanks for the link bob.
Quick Reply: Will I want to get new springs?
