Help with gauges on lt1 to ls1 swap
Ok I got the car running great. My only problems now are 2 gauges arent working. My oil pressure isnt working and neither is my temp gauge. Anyone know where I might have messed up ? Thanks in advance!
Well what year harness did you use, you will need a 98 ect sensor and run a extra wire inside to the connectors on the right side kick panels, both the coolant & oil pressure wires connect there and it is either the 220 or 230 connector, do you have a diagram of these connectors?, let me know if not I can get one tomorrow, thanks jason
ok on the white 220 connector pin B oil pressure to cluster,
pin k coolant feed to cluster , car side, engineharness coming in is pin A 220 connector, so i would move the pin from A to B in the engine harness & run the extra wire to coolant sensor , let me know if you need more help
it is my understanding we need:
Temp sensor that goes in the head
Connector needed
Granted I do not think the pix shown are the exact parts needed since it only shows 2 prongs.
After all this, I should just buy an Autometer gauge, it would be more accurate, the sensor is $21 and the connector is $15ish (and that is if the local has it....) and i know exactly how to wire that up....
Connector needed
I already have the sensor in my driver side head and it is hooked up through my ls1 harness. All I need to do is connect it in the cab i guess? Where I have no idea though
