estimated ET
Old 04-22-2008, 02:51 PM
rdrage728's Avatar
Talking estimated ET
Can anyone tell me what kind of times to expect at the strip?
I have a 96 s-10 5.3 swap with patriot stage 2 cnc heads and a voodoo cam 212/218 531/531, ls1 intake. It has a ford 9 inch with locker 3.90 gear and drag radials. The truck is about 3000 lbs with true duals x pipe and super 44s. Any ideas?
Old 04-22-2008, 02:55 PM
SprSprtChevy72's Avatar
Do you have any suspension? What trans? Also you'd prob pick up a decent amount of power from an LS6 intake as well.
Old 04-22-2008, 03:15 PM
rdrage728's Avatar
4l60e beefed up and stock suspension
Old 04-22-2008, 03:36 PM
Stall size? Id imagine you are going to have a hell of a time finding traction on stock suspension but I have no idea.
Old 04-22-2008, 03:37 PM
rdrage728's Avatar
3200 ptc
Old 04-22-2008, 03:42 PM
Are you on the S10 v8 conversion board? They can prob help you out a bunch. After reading a quick thread about racing a few guys commented low 10s would be possible on stock suspension and with a good tire.
Old 04-22-2008, 04:38 PM
rdrage728's Avatar
Smile
i will check them out thanks a bunch man
Old 04-23-2008, 08:42 AM
BLNLS1/RX7's Avatar
You should be able to get into the 12s.Good luck.
Quick Reply: estimated ET
