Rear Mount Wide Band???
Old 04-24-2008, 11:13 AM
Super Slow SS's Avatar
Question Rear Mount Wide Band???
For the guys running rear mount turbos and wide band o2's where did you put your wide band sensor. I am use to front mount stuff and it goes in the down pipe but that seems to be a bit out of reach?
Old 04-24-2008, 11:15 AM
Boosted 99 TA's Avatar
i just bought a kit from a friend and it is in the downpipe.
Old 04-24-2008, 12:00 PM
does it have an extention on the wire or do you know?
Old 04-24-2008, 12:28 PM
smoke20's Avatar
I have mine in the y-pipe - location that one of the rear O2 sensors would have occupied
Old 04-24-2008, 01:11 PM
BigBlockCamaro's Avatar
I put mine in the one of the front 02 bungs... never had a problem!
Old 04-24-2008, 01:22 PM
ZL1Killa's Avatar
neve noticed it flatline? I put mine in the downpipe, exhaust exit from the turbo, as the innovative one I had flatlined. the pressure and such changed its reading
Old 04-24-2008, 02:08 PM
smoke20's Avatar
my AEM has had no problems , knock on wood
Old 04-24-2008, 04:53 PM
i dont have a wideband yet but thats where the 02 bung is, and thats where i plan on keeping it. I dont know about any extensions he kept the wideband and wiring he left the sensor on there.
Old 04-24-2008, 07:06 PM
Blackbird's Avatar
you want it post turbo.
a few have mentioned in the past the backpressure from the turbo will screw up your readings if you keep it pre turbo
Old 04-24-2008, 09:15 PM
OUTLAWZ RACING's Avatar
I got mine after the turbo never had an issue,
Old 04-24-2008, 10:14 PM
96BIGBODY's Avatar
downpipe
Old 04-24-2008, 10:49 PM
Schantin's Avatar
Mine's in the passanger header collector. Works great for me. I also have high-flow cats, so putting it in the downpipe (after the cats) would give me a skewed reading.
Old 04-24-2008, 10:54 PM
gametech's Avatar
My LC1 would flatline rich due to pressure before the turbo. I just had to run the extra wire to get it post-turbo.
Old 04-25-2008, 08:05 AM
did you buy an extention, or did you just cut and add wire, would that be safe for the readings to get in the downpipe?
Old 04-25-2008, 08:38 AM
I have the AEM unit and I ran the wires from the rear up through the shifter under the dash to the pod. I had more the enough wire from the kit.
Old 04-25-2008, 11:07 AM
Good call I may consider re-routing the wire.
Quick Reply: Rear Mount Wide Band???
