Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
cam selection for my 406
Old 04-25-2008, 10:53 PM
botlfed's Avatar
Cool cam selection for my 406
i have a 406 i will be redoing with my new set of afr 227 cncd heads that flow 319 cfm i think at 700 -750 lift i was wondering what cam i should pick i want to squeeze every last hp out of this thing.i also drive it on the street but i really dont care how its street manners are thanks.
Old 04-26-2008, 12:19 AM
1997bird's Avatar
What kind of cam do you want to use? Hyd, Solid, Hyd Roller, or Solid Roller
Old 04-26-2008, 11:13 PM
botlfed's Avatar
whatever gives me the most power. im stuck between rebuilding my lt1 or putting the 406 in iti think i could get more power out of the 406 dollar for dollar
Old 04-26-2008, 11:35 PM
JUICED96Z's Avatar
With that kind of lift you will have more issues with valve train life and oil pressure at idle (not all have this problem as long as you change the pump springs quite a bit).
There is a guy on here that ran that kind of cam in his small block but it was a track only car if I remember.
I am looking at runing a cam like that in my new 540..........
It won't be on the street a lot, maybe 200 miles a year.
Old 04-26-2008, 11:37 PM
botlfed's Avatar
im just wondering if i should do the lt1 instead
Old 04-26-2008, 11:44 PM
JUICED96Z's Avatar
If you want a fun street car thats reliable then go LT1, if you don't care abou buying really expensive valvetrain parts and being streetable then go with that cam and a small block or even a BBC.
My springs alone looks like will cost me $300 not to mention the lifters and push rods...... and the lifters and springs will have to get replaced at least once a season to stay safe.
Old 05-05-2008, 12:33 PM
RAGENZ28's Avatar
With a 406 street strip I would go soild roller, 250/260 on a 108 with .630 or so lift.
For a race motor we run a 282/290 on a 112 with .700+ lift and we make peak power at 8,200 with our 406. Made 780 hp with 18* heads and 15-1 compression on motor.
Quick Reply: cam selection for my 406
