608 rwhp 347ci
608 rwhp 346ci
Well to start off i have to thank George from J and G tuning along with J and J Performance for helping me with my dyno and nitrous needs. The dyno was a DynoJet 224 non load dyno with a temperature of 90 degrees and 8% humidity.
Now the setup
It is a 1999 Chevy Camaro SS M6.
100% bone stock short block (stock block, rods, pistons, rings, bearings, oil pump, and timing chain) that has 84000 miles on the clock.
Performance: T-rex cam, 243 stock valve size patriot heads, gold springs, trickflow 7.400 pushrods, comp R lifters, Tr6 plugs, 10.4 taylor wires, victor jr single plain non ported out of the box, wilson manifold carb nitrous plate, custom sheet metal intake elbow, NW 90mm tb, custom 4" pipe to run from the tb to slp lid (speed density tune), FLP long tubes from 2000 (old style) to custom 3"y to 4" exhaust all the way through the back with a flowmaster muffler (nice race one not the 40 series), m6 built by t56 rebuilds, 3" steel driveshaft, moser 9" with spool and 4.10 gears, full suspension, clutch is a ram powergrip HD ( that slipped three times on the dyno) and 27" tall et streets.
Nitrous: NOS 10 pound with hiflow valve to a 6an line to a NX nitrous sileniod to 3an line to plate kit and a 4an system with NOS fuel sileniod from the fuel rails. The jets used where 65 nitrous side and 38 fuel side which is a 125 shot (suppose to be anyways).
Now the dyno:
All motor with 29 degress of timing made 438.1 rear wheel horsepower at 6500 rpm and 391.3 rear wheel torque at 5200 rpm.
At 23 degrees of timing (the tuner pulled 6 degrees) and 1025 psi made 608.4 rear wheel horsepower at 6700 rpm and 634.6 rear wheel torque at 4600 rpm.
I know there will be people that probably say BS but that is okay with me, I was there along with three others and two guys who own the dyno. I just wanted to write this to help others see that the T-rex cam witha single plain loves nitrous.
Long live the T-rex cam
If people want dyno graphs or pics of the motor or car let me know and I can email them, have to wait to fet to a scanner. Just for the record, my tuner is the main tuner for Haddad motorsports and is a complete legit tuner.
Now the setup
Now the dyno:
Hey Charles!
I looked up some calculators and it comes up as a 160-165 shot, as mentioned. Either way, very impressive for your setup. Glad I was able to help you out, we will get your new setup dailed in when it is ready.
When I hit the nitrous, it hit hard and rev'ed to 6500 quickly. The nitrous passes were started from ~3000, no need to start any lower since the car won't see less then that at the track.
thanks george, for some reason the jets are written down in the instructions and holley.com as a 125 shot, but the 160 makes more sense.
if this motor saw that power i cant wait for the new 6.6 on nitrous.
wow i was expecting people to say that a stock short block could not do 600 rwhp but i guess not. i have a feeling it will last for about 10 passes until boom.
LS1 Tech Administrator
Very believable. Congrats on the strong numbers. Glad to see you pulled timing for that size shot. Your ringlands will thank you.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
