What a week!!
What a week!!
Finally get the m6 swap complete, countless headaches along the way but that comes with it. So Im cruising at about 105 and get yanked by the 5-0. A vehicle search and 303 dollars later im back cruising. Today Im cruising go to shift into 4 and the car just dies. No injector pulse or spark, fuel pressure ok. All grounds look good. CKP sensor maybe, but i was unsure if it controls injector spark. Getting 12v's to the coils and power to the injectors.
Wow go outside today getting no injector pulse. So i unplug the drives side coil harness to check voltage, mom was in the car and hit the key and the bitch started right up on 4 plug everything back in and is running fine. Now I have a question does the crank sensor control injector pulse?
well apparently the previous owner was a complete jackass. removed the loom from the harness that goes to the ckp and that stupid ****** spliced in 16 guage wire, apparently used acid core solder and needless to say the three wires for the ckp were fucked. i have never seen so much eletrical tape in my entire life. repaired and the "nasty bitch" is back up and running.
