Blocking off the nipples anyone
Old 05-03-2008, 09:44 PM
topher455's Avatar
Default Blocking off the nipples anyone
Id like to block off the heater nipples on my water pump so I have more clearance for my crossover on my turbo setup. I clamped some rubber caps on but Im afraid they wont hold up well with the heat. Plus I could really use the 1 1/2" clearance. I thought about removing the tubes and drilling and tapping the holes to 3/4 npt and using screw in plugs. Anyone done this? Suggestions? Pics?
Old 05-03-2008, 10:19 PM
95GreenZ28's Avatar
I am thinking of doing the same thing. You go first and let me know how it goes
Old 05-03-2008, 10:39 PM
prrc's Avatar
I want to do tha same thing. I will be watching.
Tim
Old 05-04-2008, 12:42 AM
babydeuce's Avatar
Pull the nipples out, tap for NPT thread, and put a plug in them....simple as that.
Jack
Old 05-04-2008, 07:50 AM
hpmotorsports's Avatar
I hate to tell say ,if you block them off you will overheat for sure, coolant must flow through them.
Old 05-04-2008, 08:36 AM
samdogmx's Avatar
Im pretty sure there have been a few guys that have tapped & pluged them without overheating issues.
Old 05-04-2008, 09:59 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Gotta loop them.
Andrew
Old 05-04-2008, 10:58 AM
topher455's Avatar
I dont understand why overheating would occur for some not others so I looked at some t-stats I had laying around and I think I figured out why. The older style 1 piece thermostat and water neck have a flat disc on the heater bypass portion of the thermostat and the newer design has three holes on that disc allowing coolant to bypass it. I just cant see GM allowing their engines to overheat from a plugged up heater core. What do you guys think?
Old 05-04-2008, 12:26 PM
1tigers's Avatar
when you have your heat off there is no flow though the heater core. a valve opens and closes for temp you want.same as plugging lines off
Old 05-04-2008, 12:32 PM
lt4malibu's Avatar
if you plug them off it wont overheat... the meizere pump i have on my LS1 doesnt have heater hose outlets and it works just fine
Old 05-04-2008, 08:12 PM
I know I plugged mine off and at idle it would overheat, I put a loop and it cured the problem.
Old 05-04-2008, 11:18 PM
sawzall wielding director
G-Body's Avatar
On all the LSx cars that I have seen the heater core does not have a valve, it is constant flow and they regulate the heat by closing off that section of the heater box.
On my install I used the valve from the El Camino so it does shut off the coolant flow if I don`t have the heat on. A few people have said this causes problems, but I haven`t had any problems in the 25k+ miles that I have put on so far. IIRC John B was/is? running the same heater setup as me.
A few people have recommended a valve from a astro van (I forget what year) because it has a built in bypass for when you turn the heater off.
