ls1 into 1989 suburban
what parts will i need to drop an ls1 into a 1989 suburban
we want to use the 700r4 just tryin to keep it simple
where can i get mounts, brackets, etc.
If your going to install the engine into the chassis with the existing transmission I would suggest using the 1" setback mounts that we sell, You can also use your existing converter with the addition of a crank spacer and bolt kit..... The tv cable bracket can be purchases through advance adapters or s@p.
http://carshop.carshopinc.com/produc...457/C/S%202370
LS1TECH Sponsor
My 1 inch sebacks would get you close but I fear will not mate right to the trans, you may fall about a 1 inch short. You could either move the mounts on the chassis and redrill the holes or weld in new lower mounts. Just a few options, I would drop it in bolt it to the trans then dictate where the mounts need to be.....
I just need to see how much I am going to have to notch for the A/C compressor now.
