In the middle of my m6 to a4 swap need help
I am done with everything but hooking up my switches for the shifter.i bought all the plugs and need to know were to hook them up into the factory harness. i had the whole write up but must of deleted it off my computer and cant find it. if anyone knows were to splice all these i would appreciate it. Thanks
I wired up a stock a4 shifter, it had a 6 pin connector.
Top two pins are park/neutral switch.I tied those into the clutch switch wires. IF you look under there you will see the switch, its the one pressed in when the clutch is pressed in. Middle two are the reverse lights. Connect those two pins to the lightgreen and brown connector wiring from t56(pretty sure its toward the front of the tranny on passenger side). Bottom two are for the pcm to tell it how to idle i believe whether its in drive or not...i did not hook these up.
See pictures for plugs and wire colors.
http://i173.photobucket.com/albums/w...m/DSC02899.jpg
