Air Flow Research LS1/LS6 Cylinder Heads
Old 08-05-2003, 09:08 PM
Speedfreaks101's Avatar
Default Air Flow Research LS1/LS6 Cylinder Heads
I was told today by a friend that AFR is supposed to be bringing an aftermarket version of the LS1/LS6 cylinder head. Does anyone know if there is any truth to this? With cylinder heads achieving 350 cfm it is hard for me to see where they are going to improve....Lets see 430 cfm from a "LS1" head, sounds nice. Also if there is any validity to this then maybe an aftermarket block (besides the C5R race block) is not far behind.
Later,
Bart
Old 08-05-2003, 09:12 PM
Restricted User
CAT3's Avatar
Default Re: Air Flow Research LS1/LS6 Cylinder Heads
heard the same thing almost, but was hinted that they are also developing an intake to compliment their NEW casting heads. Will see about calling them on this, like they will tell me anyway, but maybe you never know what you dont know.
Old 08-05-2003, 09:20 PM
strokedls1's Avatar
They were asking people to let them test out peoples aftermarket ported heads, so they could find the best design and copy it. Sounded like a shaddy deal for the people willing to let them use their heads. The only compinsation was a discount on their new heads. I'll stick with what I have.
Old 08-05-2003, 09:25 PM
If it is true then I hope they don't stray too far from the origional port design.
Old 08-05-2003, 09:30 PM
If you are right then I will be waiting to see what the LS2 brings.
Old 08-05-2003, 09:44 PM
Freak's Avatar
that 350 CFM will be at somewhere around the .600 lift area, im sure. any improvements to be had will probably be in the low to mid lift area, the valve spends more time there so that would make a bigger difference than at the max lift...
I would definelty like to know if this is true though...
Old 08-05-2003, 10:16 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
The AFR rumor I heard was 400cfm at ~.600 lift out of the box. I don't think they'll get 400cfm copying anyone current LS1/LS6 ported heads.
Old 08-06-2003, 11:45 PM
SStrokerAce's Avatar
I am a AFR dealer and one of the guys there, specifically the guy who designed the BBC heads said we will have three heads available a 205cc a 225cc and a 245cc, the competition ported 205cc will flow slightly over 300cfm. That is what I remember from the conversation. I will get a set of these and send them to my head porter to see what he can do. (He has pushed 340cfm out of a AFR 195, so these should be interesting.)
I would imagine that since they are like a LS6 head in design that we should see 350+cfm out of a well ported one. If I hear any news on these heads I will post what I hear.
Bret
Old 08-06-2003, 11:52 PM
quickWS6's Avatar
What kind of price will they have? Typical AFR aftermarket price, or typical MTI/GTP ported head price?
Old 08-07-2003, 08:36 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I talked to the engineer at AFR working on the LSX heads. Sounds like they will be released at the end of the year. Planning to release 2 at first, maybe a 3rd later.
Old 08-07-2003, 10:20 AM
Vents's Avatar
"If it is true then I hope they don't stray too far from the origional port design."
why would it matter? reguardless of the port design(could be a series of triangles w/ a circle and a rohmbus in the port and still flow 320 cfm becaise it's AFR. besides, maybe it'd make more torque that way.
Old 08-07-2003, 10:48 AM
CHRISPY's Avatar
I would like to see what the 225CC and 245 CC heads flow
Old 08-07-2003, 03:27 PM
Nickn20's Avatar
I like where the LS1 is heading finally some heads and intakes for us!
Old 08-07-2003, 08:20 PM
Skelton's Avatar
AFR will put out quality for sure. They should be well designed all the way around and besides, as cheap as you can get some good cnc ported stockers, they will have to keep the price down.
Old 08-07-2003, 10:43 PM
The pricing should be pretty close to the 210-227cc LT4 heads, in bare, Race porting and Competition porting.
Bret
Old 08-07-2003, 11:52 PM
Freak's Avatar
Bret
how much is that?
Old 08-08-2003, 12:05 AM
FrankSS's Avatar
should run from 1800-3000 a pair, knowing how they do their pricing
Old 08-12-2003, 05:12 PM
Vents's Avatar
im leaning closer to the 3k side..
Old 08-15-2003, 01:30 AM
My guess is that the bare heads are going to be around $940 a pair, so pretty close the LS6 castings. The fully CNC ported probably from $2100-$2600, but as guys have said, error on the high side of that to be safe.
I know I am going to get some heads when they are available and have them ported, just to see how good they really are.
Bret
Old 08-15-2003, 07:30 AM
Dumb Ass Vette Moderator
ls1290's Avatar
If they do come out, I can not see them using a different port design. If they do, then a new intake will be needed. Then again, if they flow 350+ cfm and the intake matches the flow, I woul ddump my current setup
Quick Reply: Air Flow Research LS1/LS6 Cylinder Heads
