Pics of EPP FMIC on T/A?
11Second Club
Hey all,
I've seen some really nice pics of FMIC setups on T/As where various things were done to get air through the IC. I don't mind chopping the license plate cover and such, but I really want to keep the fogs. Anyone got pics of such things?
Thanks in advance.
Thanks in advance.
These aren't the EPP FMIC but checkout the links below...
https://ls1tech.com/forums/showthread.php?t=631954&page=9
https://ls1tech.com/forums/showthread.php?t=906224
Our kit does not have current provisions for keeping fogs, better flow to the core.
Cutting the license plate holder is the best way to clearance for more airflow as well.
Is this EPP's fmic setup? Ive got a 1996 ws6 i will be adding a fmic to, and am actually going to buy it from EPP soon..also have you measured your IAT's with only the fogs missing? Im thinking about not cutting out a hole in the front bumber and doing what you did...
The core fits with our brackets on the lt1', and the up pipe setup should fit, the blower to IC pipe needs to be modded to fit as far as im aware of. Currently we do not support the lt1 cars.
I have a picture on my computer at work of the EPP FMIC installed on my 2k1 TA... I'll post it tomorrow.
I was in the same boat as you, i was hoping to be able to keep the fogs, but with EPP's kit, unfortunately you are unable to do so.
It's all good the, the "cool" factor, and evil look the front of the car has, its worth losing the fogs!!!
I'll post em up first thing tomorrow morning.
Thanks...
--Mike
Thanks...
--Mike
Camaro pic's with EPP front mount intercooler kit
We made my intercooler tubing out of aluminum instead of mandrel bent mild steel tubing that we use in our front mount intercooler kits.
Here is the link to our front mount intercooler assembly.
http://www.exoticperformanceplus.com....html?item=772 Bob
I made my own but I was able to keep the fogs for show, it didn't have room to actually hook them up though. Next time around I'm going to try and make room for them to be functional. Pic of old set-up in sig.
