Pressure Plate Bolts
Old 05-09-2008, 01:48 PM
Turnin20s's Avatar
Default Pressure Plate Bolts
Can you get them at the dealer or does APR or someone else make a good set? I didn't get any with my T56 swap and am going to need them pretty soon. I'm going to stop at the dealer today, but post me a part number if you could.
BTW its for an LT1 car
Old 05-09-2008, 02:40 PM
CaMaRo67RS355's Avatar
i looked on ws6store.com and saw the ARP flywheel and pressure plate bolts for 98-02 fbodys but not the lt style id call ws6store and ask them cause they might not have them added on there site
Old 05-09-2008, 02:48 PM
9000th01ss's Avatar
I got mine from the local ACE/ True Value hardware store. Grade 10.9 metric, as strong or stronger than grade 8 sae. Forgot the size.
Old 05-09-2008, 06:15 PM
BALLSS's Avatar
Default FW bolts
http://store.summitracing.com/partde...t=ARP-200-2807
http://store.summitracing.com/partde...1&autoview=sku
Old 05-09-2008, 06:17 PM
9000th01ss's Avatar
I think he said pressure plate bolts.
Old 05-09-2008, 06:21 PM
BALLSS's Avatar
note the edit,
use lock tite on the bolts
Old 05-09-2008, 10:28 PM
Bones Z28's Avatar
Ditto!!!! I'm interested if anyone else knows where to get them. I'm in the middle of doing a trans rebuild and a new clutch/pressure plate. I talked to summitracing and they said they don't carry a set of pressure plate bolts for LT1s specifically. I see LS series all over the place but nothing for a LT1. Summit just carries the flywheel 12pt bolts from ARP that's it. I called up ARP (summit gave me their number) and the guy on the phone was just a butt head, kind of dazed and confused so that got me nowhere. So I'm still on the hunt for a set of pressure plate bolts, preferably ARP and of course for a LT1 car. Some please help us out here.
Old 05-09-2008, 11:19 PM
Black99T\A's Avatar
I just got all my bolts for my swap at the local dealer, they wont rip you off on the bolts like they do everything else. I got my flywheel and PP bolts there. they had to order them but they had them in the next day. actually I ordered Flywheel bolts, PP bolts and Trans. to bell bolts I think all of it together was like 28 bucks or so. flywheel bolts already came with blue loctite on them too.
Old 05-10-2008, 11:13 PM
Turnin20s's Avatar
Went to the dealer yesturday and ordered them, but the page he pulled up was for a bolt 31/32" long. When I got out to my parents I looked at my brothers bolts and the flywheel bolts are 31/32" and the pp bolts have a shank and are about 1.25" long. I needed the flywheel bolts anyway, hopefully I'll get a hold of him early enough that he can order the right pressure plate bolts so I get both sets at the same time.
Old 05-11-2008, 01:37 AM
meatyshells's Avatar
(lt1) gm# 10079898
(ls1) gm# 12561465
gmpartsdirect.com or give that number to a dealer
Old 05-11-2008, 11:36 AM
Turnin20s's Avatar
^^^Thank you very much
Old 05-12-2008, 12:17 PM
Mr. Trick's Avatar
Originally Posted by ******
note the edit,
So you need to put lock tite on the preasure plate bolts? Good to know cause I'm starting my a4-m6 swap today.
Old 05-12-2008, 12:31 PM
Turnin20s's Avatar
Just to let you guys know the bolts for the pressure plate were $4 each and you need 6 of them, then the flywheel bolts are $2.39 each so I have about $40 just in 12 damn bolts.
Old 05-12-2008, 05:31 PM
sucks to have an lt1
Old 05-13-2008, 12:15 PM
Turnin20s's Avatar
Yeah but I'd still take my LT1 over alot of LS1s
Old 05-13-2008, 08:29 PM
Black99T\A's Avatar
man that really sucks
Quick Reply: Pressure Plate Bolts
