STS Meth injection or FMIC Opinions
Old 05-13-2008, 12:18 PM
witry's Avatar
Default STS Meth injection or FMIC Opinions
well soon here im going to be installing a sts kit on my Trans Am ill run 5 psi DD or 8 occasionally the kit i got came with the meth injection should i use the meth or since i got the FMIC i should be fine with it.. also dont forget i live in FL so it gets hot here but its not ganna see 8 psi in the day time tho so should i install the meth along with the FMIC or just the FM is fine?
Old 05-13-2008, 12:24 PM
Schantin's Avatar
Should be fine with the FMIC. If you have both, never hurts to install both You'd want the meth when running 8PSI, even if it's only occasionally. Just my $0.02
Old 05-13-2008, 12:45 PM
RW99's Avatar
Install both, you won't regret having the methanol available for your higher boost settings. Just make sure you've got a good wideband in the car, and have it tuned professionally.
Old 05-13-2008, 12:51 PM
witry's Avatar
ohh yeah i got an autometer wideband and its ganna get fully dyno tuned
Old 05-13-2008, 05:15 PM
02 hawk's Avatar
if you can get both get them, one will do according to the guys at sts....post pics up
Old 05-13-2008, 07:39 PM
12 Second Truck Club
TURBHOE's Avatar
who makes the sts meth kit? i got one used. i would recommend useing it too.
Old 05-14-2008, 08:22 PM
witry's Avatar
should i use the STS pump or upgrade to the alkycontrol pump?
Old 05-20-2008, 07:40 AM
AIS
AIS's Avatar
Be sure to check out our special "black" series pump made by Shurflo. Our pump is engineered for use with 100% methanol.
http://www.alcoholinjectionsystems.com/images/methanol_pump_l.jpg
Old 05-20-2008, 08:01 AM
TURBHOE's Avatar
That one looks just like the one my sts kit has.
Old 05-20-2008, 09:05 AM
How do I change this text
Wilde Racing's Avatar
The STS Alky kit is just a on/off set-up (unless they changed the system) I'd recommend AlkyControl, or like from a sponsor...
and
Another vote for both FMIC and ALKY...
Old 05-20-2008, 02:41 PM
ZL1Killa's Avatar
also check out my build that is in my signature
Quick Reply: STS Meth injection or FMIC Opinions
