wheel hop
Location: rochester ny/ cannon air force base, new mexico
1 Post
wheel hop
had terribe wheel hop after i installed nitto nt01 drag radials with stock suspension but i just recently installed umi torque arm, panhard bar and lower control arms and went back to the stock springs which have less then the eibach prokit ones i had in there. anything else i can do to help prevent wheel hop?
with lowering springs you should install the lower control arm relocation brackets, it brings the LCA down and aligns them with the body so they can do their job.
that is why the wheel hop wasn't as bad with the stock springs, but throw your lowering springs back in and the relocation brackets and bye bye wheel hop. or get some drag springs for the rear, alot better than the prokit for drag.
btw: wheels hop breaks rear ends, so dont do too much crazy **** until you get those relocation brackets.
1 Post
yeah i broke my rear end last year because of wheel hop but i am going to go get new struts and do the relocation brackets might we well right it cant hurt
