wheel hop
Old 05-14-2008, 07:54 PM
orange1999ws6's Avatar
Location: rochester ny/ cannon air force base, new mexico
Default wheel hop
had terribe wheel hop after i installed nitto nt01 drag radials with stock suspension but i just recently installed umi torque arm, panhard bar and lower control arms and went back to the stock springs which have less then the eibach prokit ones i had in there. anything else i can do to help prevent wheel hop?
Old 05-14-2008, 08:04 PM
DevilDougWS6's Avatar
with lowering springs you should install the lower control arm relocation brackets, it brings the LCA down and aligns them with the body so they can do their job.
that is why the wheel hop wasn't as bad with the stock springs, but throw your lowering springs back in and the relocation brackets and bye bye wheel hop. or get some drag springs for the rear, alot better than the prokit for drag.
btw: wheels hop breaks rear ends, so dont do too much crazy **** until you get those relocation brackets.
Old 05-14-2008, 08:05 PM
BMR Tech's Avatar
How many miles do you have on the current shocks on the car? a high mileage shock can loose its proper dampening and this could be a contributor to wheel hop. There are several styles of shocks available,you just need to choose the right one to meet your own goals for your car.
Old 05-14-2008, 08:07 PM
waterbug1999's Avatar
When I lowered mine = wheel hop.. Lowered car + LCA relo's = no wheel hop. This is with cheap azz autozone monroe shocks.
Old 05-14-2008, 11:24 PM
Sunset'01Z's Avatar
guys, he went back to stock springs.
look into shocks man.
Old 05-15-2008, 09:26 AM
transam69230's Avatar
Just throwing it out there but if the pinion angle was off would that cause wheelhop at all? I know it causes vibrations in the pinion angle is off. I never had issues with wheelhop with my car. Just an idea cause he said he put a new trq arm on.
Old 05-24-2008, 08:15 PM
yeah i broke my rear end last year because of wheel hop but i am going to go get new struts and do the relocation brackets might we well right it cant hurt
Old 05-25-2008, 08:01 AM
Redlinez's Avatar
Mine wheel hopped on stock springs, stock shocks and street tires on the street! I just put Moog LCA bushings in and it seems much better, but I'm planning on rear shocks as well.
Old 05-25-2008, 09:24 PM
94'BLKBRD's Avatar
You definetly need some LCA relocation brackets
Old 05-28-2008, 04:12 PM
BMR Tech's Avatar
Not that I have ever seen......
Sounds like a good plan
Quick Reply: wheel hop
