disappointed with results....
car is heads/cam/intake, 9 inch, full suspension.
first off Im a track newbie and pretty much suck...
my best run prior to all the suspension and gears was a 12.65 @ 110. w/ a 1.95 60 foot.
tonight at the 8th i couldn't run better then a 8.3 @ 88mph.
for my mods im thinking the trap is pretty low, obviously my launch sucked w/ a 2.0 60 foot.
I either bog, or spin, im on nitto 555R's. leaving at no more than 1500rpm
the qa1's were set at 3 up front and 5 in the rear. pinion angle is -2
now the weak side is im on the stock clutch still yes I know stupid. but its all I got till tuesday, then the ls7 and built t-56 go in.
leaving the track I noticed it was slipping (no surprise) when I swap to the ls7 will I notice a gain in mph?
any tips on how to launch w/ nitto's and the ls7?
track newbie needs some help guys.
Chad
Chad
With my old head and cam I ran a 7.40@96 but I had a built 4l60e. No matter what we did I couldn't hook with the Nittos. I went to MT DRs I ran 22psi in them. If memory serves me right I had to run less in the Nittos. Right now my pinion angle is -2 also not sure on what my QA1s are set at. I will see if I can get Greg to look before we head to the track Saturday night.
your heading up to moroso tom night correct? pm or post up the shock settings please!
twofast- running 275/40/17 nitto DR's....not trying to leave hard at all...basically leaving from a stop light i'll bog real hard, and if i try to slip the clutch at all spin city.
maybe I just can't drive
edit: ls1queen how much power was the car making for the 96mph trap?
im thinking I should be somwhere around that ballpark trapspeed....
Chad
I wouldn't say he's pushing the limits of Nittos. I yanked a 1.78 out of mine (same 275/40/17) when the car was only trapped a 111, but with your current power, I'd definitely upgrade to those 26 x 10.5 MTs you mentioned. Funny thing, I just mounted the same tires on my 16" rims Saturday for the track rental coming up this Friday. I, too, am H/C, although very mild (400/367), but I'll let you know how they hold up. Watch out for a post from me late Friday night or Saturday.
If I got a 1.78 out of the Nittos, I'm hoping for a consistent 1.6 (depending on my driving), from the MTs. Plus I'm trapping a good 5mph more now that I'm tuned.
I would also get rid of that stock clutch and go with something like a Textralia if you track it a lot. I've heard a lot issues with the LS7s glazing over at the track on hard launches, which is exactly what you need to get the times you're looking for.
reason I went with the ls7 I got it for $100 bucks off a buddy who blew up his motor. so....I'm eventually going to go w/ the tex when I can.
Chad
