Which pushrods to use for LS6 cam swap?
I know that Comp makes two for the Gen III engines. IIRC they have a cheap one and a nice one. I think the nice one is like $20-$25...not bad at all.
I have heard of people running the 5308 cam with their stock (or stock length) pushrods with no problems.
help with my 5.3l ls6 cam swap
im having trouble i put a ls6 cam in my 5.3l and im having trouble it idles fine but it feels like its lacking power and when i rev it or accelerate it bogs down when i let off and some times dies. i turned the o2 sensors off to correct the random multiple misfire code and i changed the downstream o2 sensors and still no luck im at my wits end please help!
7.425 if you don't use LS6 heads with the longer valves, but I have heard the 7.4's will work, but you won't get the full lift of the cam, although we are only talking about .025" here plus the flex of hyraulic lifters.
